TV Distrubution
This post has 18 Replies | 2 Followers
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Sun, Jun 21 2015 11:04 AM
Hello All
I currently have a Beovision 7-55 in my main room providing SD dist to a BV3 and BV6-26
With the move to my Beosound Moment and the NL/ML convertor I will more than likely over some time move to more NL than ML devices as i love the concept and possibilities.
Few questions, if i change the TV;s in link rooms to NL devices they dont accept Link Video which is fine as i prob should move away from this anyway at some point.
My question is what is the best way for this, my main room has Bluray, Apple TV and SKY HD, woudl the best solution be a Matrix on the BV7 or perhaps some form of hdmi splitter with Baluns.
If I went for the splitter i suppose i would need 4way splitters that also carry IR or at least the Balun should carry IR.
the way i figure i will need baluns anyway no matter which method i went for.
Thouhgts (not about the moment)
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
StUrrock
Posts 995
StUrrock replied on Sun, Jun 21 2015 11:34 AM
Seanie_230:
Hello All
BLGW - Rekindling the love of ML
prices for HD matrices are really dropping now
also with recent developments no need to stick with altona HD switchers etc
Cyp make a single source HDBT sending kit over cat 5 to up to 4 displays (I believe) but for just a few hundred more you can have a 4x4 matrix with 4 HD values (also with 2additional mirrored hdmi out)
Griebel
Posts 416
Griebel replied on Sun, Jun 21 2015 11:50 AM
StUrrock:
Glad to hear that the prices of the HD matrices are dropping. The Atlona ones were seriously overpriced (not even mentioning the charging of the activation code for each source. Unacceptable!)
mjmedlo
Posts 922
mjmedlo replied on Sun, Jun 21 2015 1:29 PM
Be careful to make sure you have puc control through the matrix. That's what Atlona is the b&o recommendation.
StUrrock
Posts 995
StUrrock replied on Sun, Jun 21 2015 2:06 PM
mjmedlo:
our solution works with any puc code as the matrix in question can learn any code
it seems someone at Struer got tAken out for a nice expensive lunch from someone at Atlona
why couldn't Struer write puc codes for other brands?
Ridiculous
mjmedlo
Posts 922
mjmedlo replied on Sun, Jun 21 2015 3:02 PM
I'm not disagreeing.
The Atlona is ridiculous.
What solution do you speak of.
Time for some research!
StUrrock
Posts 995
StUrrock replied on Sun, Jun 21 2015 3:28 PM
mjmedlo:
are you in the UK?
mjmedlo
Posts 922
mjmedlo replied on Sun, Jun 21 2015 3:38 PM
No
U.S.
Seanie_230
UK
Posts 2,278
StUrrock:
are you in the UK?
What is the alternative UK
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
rednik
Posts 182
rednik replied on Sun, Jun 21 2015 4:28 PM
Seanie_230:
StUrrock:
are you in the UK?
i would also be interested to know this.  Not going to help with your BV3 though.
rednik
Posts 182
rednik replied on Sun, Jun 21 2015 4:45 PM
Seanie_230:
StUrrock:
are you in the UK?
StUrrock
Posts 995
StUrrock replied on Sun, Jun 21 2015 5:38 PM
rednik:
Sorry did not mention that over the next couple of days we are finalising testing of this alternative matrix brand from a BVIS Avant 55
Initial tests looking good
will report back
Seanie_230
UK
Posts 2,278
Will this work with the BV7-55 ?
I know I would need to ditch the BV3 & 6 for newer TV's that at least have HDMI.
beovision 3 first maybe a nice V1-40
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
StUrrock
Posts 995
StUrrock replied on Sun, Jun 21 2015 9:11 PM
you will still need the activation code for 7-55 or v1 in order for all or codes to be sent out of one single puc socket
bvis 11/avant 55 75 85 do not need activation code for this
Seanie_230
UK
Posts 2,278
HI all
just chatting to a dealer who informs me the activation key for the HDMI Matrix is actually FOC these days.
the 8x8 matrix is overkill and the 4x4 is £3200 which is the cost of a second sky box for 64 months so not worth it.
I think i will loose my Link TV in my kitchen and just buy a splitter for the HDMI out of my Sky and Apple TV box.
No need to spend a fortune on things that wont offer me anything.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
StUrrock
Posts 995
StUrrock replied on Tue, Jun 23 2015 2:12 PM
Seanie_230:
HI all
£3200 what a rip off ours is £1795
with 4 baluns and 2 mirrored outputs
is 4k compatible (may require minor chargeable hardware upgrade)
and controllable from web browser also has hdmi cec control for 3rd party tvs
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Tue, Jun 23 2015 2:58 PM
Seanie_230:
Hi Seanie
FOC if you buy a matrix from them or FOC full stop?
Martin.
StUrrock
Posts 995
StUrrock replied on Thu, Jun 25 2015 10:38 PM
all tested all good Big Smile
PM me for the spec
w5bno123
London
Posts 578
w5bno123 replied on Fri, Jun 26 2015 12:20 AM
Seanie_230:
HI all
What exactly have you been quoted for that amounts to £3200? Do you have a breakdown of costs as this seems little on the high side Unsure
Page 1 of 1 (19 items) | RSS
