Reducing the tonearm noise of Beogram 3000
caligula
Posts 1
caligula Posted: Mon, Jun 22 2015 2:01 PM
Hello,
I recently bought a Beogram 3000 from 1974. The player works well with one tiny exception - when the tonearm moves (especially when moving back to its' rest position) it makes a squeaky noise. I believe that I have to grease the tonearm but how should I do that in detail and what grease or other product should I use therefore?
Steveric
France
Posts 29
Steveric replied on Mon, Jun 22 2015 2:51 PM
Hi Caligula,
The only advice, it's to use Silicone Grease instead of any WD40 and so...Wink
I don't own this kind of turntable, but on my 4002 that was I did.
Probably will be useful to get the service manual of your Beogram 3000 which will help you a lot to achieve this.
Dave Farr
France
Posts 2,283
Dave Farr replied on Mon, Jun 22 2015 2:58 PM
Do not use WD40 under any circumstance - it causes corrosion.
Almost any PFPE grease can be used or PTFE grease.  Use it on both runners and lubricate the full length.
Dave.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Jun 23 2015 6:43 AM
The squeeky noise probably comes from the tiny tip of the lift pin.
First attempt would be a good cleaning of the tip and its race on the aluminium lift plate.
Lubricating it could cause other problems because the mech relies on the friction.
Page 1 of 1 (4 items) | RSS
