Masterlink and Cat 7
This post has 7 Replies | 4 Followers
kai
Posts 362
kai Posted: Thu, Jun 14 2012 12:23 AM
I posted about using cat 7 round the new house thanks for all the replies. I'm now looking at what I need for connections, when I want to terminate the cable into a wall outlet can I use any cat 7 connector!! Also back in the cupboard can I use any cat 7 patch panel, would appreciate your thoughts guys on this as I need to get the patch panel and connectors soon
Kai :)
ouverture
London
Posts 263
ouverture replied on Fri, Jun 15 2012 11:06 AM
I am looking at this as well, once you have all your Cat7 back at the cupboard, whether into a patch panel or not, you will need to open the cable to expose the 8 wires and cross connect every Cat7 run with each other, a sort of home made junction box, that is what I have been told so far, I think this is quite easy once you have sourced a suitable plastic box to house the cables.
kai
Posts 362
kai replied on Sun, Jun 17 2012 1:32 PM
I would have thought once you have everything back to the cupboard, with the correct cat 7 patch panel, you simply just patch the lead to the correct number on the patch panel, otherwise you might as well use masterlink cable and a junction box!!
ouverture
London
Posts 263
ouverture replied on Sun, Jun 17 2012 3:52 PM
sorry, I was still thinking about my house, and using Cat6 or Cat7 to get Masterlink back to a cupboard
http://archivedforum2.beoworld.org/forums/t/1277.aspx
you are doing away with ML all together, sorry for the confusion.
RussR
Posts 63
RussR replied on Sun, Jun 17 2012 5:58 PM
Hi Kai,
Too early on a Sunday after too late on a Saturday, so forgive if this is a little fuzzy.  Cool  You ought to be able to use just about any Cat 7 ends/wall plates.  But please note:  there are two ways to terminate Cat 7, A & B.  Bang & Olufsen have chosen B, which ought to be easy to remember.  Smile
You can certainly go through all of the bother of cross connecting all of your Cat 7 runs by hand, but B&O can provide a pre-made patch panel which gives you 6 slots, so 1 in, and 5 out; and if need be you can daisy-chain two or more together.  Part number 8052351 and approx $135.00 each here in the US.  Similarly there is a PL patch panel #8052352, same price, meant to feed 2 pairs of BeoLab speakers.
All you need after that is a box for all of the panels, and, of course B&O offer that as well: #3400206, $160USD.    Thee is also an assortment of brackets for that box and 19" rack-mounts.  I can't remember if there is anything else required, but your local shop ought to be able to provide any additional details.
I hope this helps!
Russ
We kid because we love.
kai
Posts 362
kai replied on Sun, Jun 17 2012 7:12 PM
Hi Russ
Thanks for your reply, and for the parts numbers, I will have a look at them good to know you can use any connectors, I used to work for local b & o store, I know how to wire cat cable, I'm pretty sure you could use cat 7 patch panel, but will check it out. :)
Scott Needham
Paris, France
Posts 217
hello,
i wired my house with ethernet cables as it seems you are planning to do.i use the lexcom home solution. it is based on two things :
1\ a 'router' masterlink or powerlink in the patch panel
2\ lexcom cables for rj45-masterlink and rj45-powerlink
i am very pleased with the solution, though it may be possible to d.i.y. for less.
have a look. if you want more information, don't hesitate to ask.
- scott
kai
Posts 362
kai replied on Mon, Jun 18 2012 10:34 AM
Yeah I have heard of the lexcom system, but I was wondering can you use a standard cat 7 patch panel!
Page 1 of 1 (8 items) | RSS
