.....and what is that supposed to be?
(Apart from a sentimental flashback of the 'good old times').
Millemissen:.....and what is that supposed to be? (Apart from a sentimental flashback of the 'good old times'). MM There is a tv - and there is a BV.
Raeuber: But first of all it's an eyecatcher for any livingroom with no need to hide in a cabinet. Räuber
Räuber
Apart from the technical issues - it would certainly be a matter of taste.
Millemissen:.....and what is that supposed to be? MM There is a tv - and there is a BV.
With the exeption of the 'integrated BeoMusic app' you fairly just described the BS Moment.
Note: PatternPlay and MoodWheel are not an app - these are the functions, that the BS Moment is built around - the basis of its interface.
Millemissen:With the exeption of the 'integrated BeoMusic app' you fairly just described the BS Moment. Note: PatternPlay and MoodWheel are not an app - these are the functions, that the BS Moment is built around - the basis of its interface.
@BeoBoy68
Maybe you should start to think of making your own company - start crowdfunding
Millemissen:@BeoBoy68 Maybe you should start to think of making your own company - start crowdfunding MM
leosgonewild:Drama queens...
