Oh no. Another one destroyed in the post. Turn to the seller and ask for a refund.Seems the dustcover was pressed downwards with enough force to bend the tonearm (!), the same force also brokethe holding clip on top of the tonearm rest when that part of the tonearm was pressed upwards.I suggest you check the tonearm pivot points. They must have seen an immense overload.
Dillen: Oh no. Another one destroyed in the post. Turn to the seller and ask for a refund.Seems the dustcover was pressed downwards with enough force to bend the tonearm (!), the same force also brokethe holding clip on top of the tonearm rest when that part of the tonearm was pressed upwards.I suggest you check the tonearm pivot points. They must have seen an immense overload. Martin
Agree with Martin, I was just checking my spares, thought I had a tonearm laying around, I do but it is for a 1200 series, so that wont help you
Ben_S:Bought myself a 42VF the other day and it has just arrived via post. Look at the state of the dust cover though. Arrived in a terrible state and it is really annoying because the covers are really rare.
Exactly that happened to me too two years ago, as I got my second 42VF (first one with dust cover)!
The sellers simple do not understand how important the packaging of TT and its cover is (or they are simply not capable/interested to do it properly!)
Shame...
I wish you to find another dust cover in the near future and to manage the rest of technical problems on the TT. Unfortunately I do not have any spare parts but I will ask few friends too...
Good Luck!
Vintage Bang & Olufsen
Thanks Søren that is kind of you for looking!
And Theomaster, I saw an earlier thread actually where yours looked the same. It is immensely frustrating especially as the dustcover was an optional extra and there aren't too many about as you know!
Hopefully I will find another one soon though and fix the tone-arm issues!
Ben
