Moving the moment
This post has 22 Replies | 2 Followers
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Sat, Jun 27 2015 4:42 PM
Hello all
As some of you may know I have the moment tied into a full ML system.
The moment replaced a beosound4 which had its own speakers connected to it.
When I bought the moment it was not able to sent sound to ML and its own speakers which started to annoy me but the software update was coming.
Well today I decided to give it a go and move it and play with some settings
First thing was to try and connect my Penta three speakers to it, they did nothing.
Second step I though ok I will configure the wired speakers and see how this goes. Locate worked well so I though OK that's it.
No sound.
Next step was to try selecting NO on the option use TV speakers which I though had to be set to yes if using an ML setup. I was wrong as soon as I selected NO to TV speakers the penta's come on.
I went to my link room and pressed radio and I got radio and the moment screen said distributing which was cool.
So far so good......
I tried radio and other sources in my main room with BV7 and this worked too.
So now I have replaced my audio master and can still take sound to other rooms.
The problem is when selecting wired speakers it gave me the option for beovox 1,2, line or other. I tried them all and trust me line made me jump when the penta came on very loud.
So I selected other and the display was blank. Back to Beovox and he lies the problem. The penta display says ATP2 __ and volume.
If I turn the volume wheel while I'm turning it says load tape then goes away back to ATP2__ new volume which is good.
So after speaking to a dealer they moment is supposed to be fine with the displays.
Nearly nearly there. I have ML working properly and sound connected to the moment too but only problem is the penta display which I'm sure I will overcome.
Connecting the penta to active it works fine.
I think the issue here might be that in the ML side CD is mapped to Music so it works but on the moment the data connection in power link might be different I don't know.
Secondly I have not tested yet but I'm sure I will have an echo and I'm returning the delay box as I'm not paying £300 for it when I'm sure an alternative can be found much cheaper.
All in all much happier today and the software update has given me more functionality. The beo music app will be updated soon to offer more options too.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
Seanie_230 replied on Sun, Jun 28 2015 11:01 AM
Nearly in place just need Togo buy a four port switch and I can hide all the cables
I love the artist appearing behind the track when playing
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Aussie Michael
Melbourne, AU
Posts 3,730
Seanie_230:
BLGW - Rekindling the love of ML
My Sony Xperia z3 does that too in the lock screen and I love it too Lets have a Party !!!
Seanie_230
UK
Posts 2,278
Seanie_230 replied on Sun, Jun 28 2015 11:10 AM
Beautiful isn't it and it fits in with the room perfectly.
Just the penta display to figure out but I'm sure I will get there
Now need to find a lovely replacement unit and get my skirting boards on :)
SurpriseSurpriseSurprise
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Jun 28 2015 12:39 PM
Seanie_230:
two remarks:
1. does the setting of the switches Audio/video on the Penta's make any difference?
2. is the adapter between the Moment and the tradition PL cable correct?
Seanie_230
UK
Posts 2,278
Seanie_230 replied on Sun, Jun 28 2015 12:50 PM
Hi there
To be honest I have not touched the switches as they were on Audio before so i left them that way.
I will test it.
The adapter on the Moment is a Ethernet to PL convertor which I have the normal Powerlink cable plugged in.
the volume works fine but it says ATPE2 in the display no matter if its on or off.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Chris
Ostend-BE
Posts 1,170
Chris replied on Sun, Jun 28 2015 1:13 PM
Seanie,
I have never been in possession of Penta's so I can't make a comment. But I'm happy you enjoy the Moment as much as I do from the beginning, with the multiroom its getting more mature and I'm sure it will grown a lot more in the near future.
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Seanie_230
UK
Posts 2,278
Hi Chris I agree
Great device and even better functionality since the update, I'm sure there is more to come for sure.
I have now just configured my essence remote in IR mode to receive and send commands via the moment, (home automation pass through enabled)
Now when I press up the lights come on, down lights go off. Left pattern play starts for the mornings and right room stay by. Got to love automation and NL.
Also switched a penta to video mode and now there is no display. I'm sure someone at bang and olufsen will know the solution and I'm sure it's mapping the powerlink data.
Music has been on all day.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
BeoMotion
Posts 384
BeoMotion replied on Sun, Jun 28 2015 1:59 PM
Seanie_230:
I don't think that there is any solution for this at the moment. Had the same issue with BS Moment and Penta II some time ago. The only source name that was shown was A.TP2. Additionally there was also the volume number on the Penta screen. Don't know why this isn't available on yours...
Seanie_230
UK
Posts 2,278
Hi there
Thank you for coming back to me.
I have the volume shown.
The ATP2 is shown no matter of the moment is on or off.
If I use the moment the screen flicks to load tape for a new mins.
Let's hope there is a fix coming.
I will report to beocare
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
all cables hidden away
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
BeoMotion
Posts 384
BeoMotion replied on Sun, Jun 28 2015 3:21 PM
Seanie_230:
Hi there
Oh, yes. I can remember that LOAD was also shown several times.
The displays only switched off when I pressed the on/off switch on the base station.
Personally, I don't think that they will put much effort into fixing problems with 20 years old speakers.
But lets see. You should definitively open up a ticket for this. The more people are doing this the better are the chances to get that fixed.
tournedos
Finland
Posts 7,357
tournedos replied on Mon, Jun 29 2015 7:40 AM
They might be able make the displays switch on & off properly, but the source names are hard coded in the firmware of the Pentas. I very much doubt anything will happen to them as it would need a chip replacement.
--mika
BeoMotion
Posts 384
BeoMotion replied on Mon, Jun 29 2015 8:06 AM
They could at least show some different source names rather than always A.TP2.
E.g. RADIO for TuneIn and CD for DLNA and CD2 for Deezer. Shouldn`t be too hard but I doubt that it will happen.
Seanie_230
UK
Posts 2,278
Seanie_230 replied on Mon, Jun 29 2015 12:57 PM
Hi All
So i spoke to Bang & Olufsen today and the moment will not output the fixed data to tell the Penta speakers what to display, in fact the response was to cut the data wire.
So next question:
Can a small device be created that would for example receive from Moment  xxxxdataxxxxMusic and this device set to output xxxxDataxxxxxCD
this device could receive one signal and output another like the lintonic perhaps but a very drilled down version for Speaker powerlink.
Would that be possible?
Any thoughts?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Millemissen
Flensborg, Denmark
Posts 14,680
I stopped missing the 'display infos' on my BL5000 long ago.
BeoMotion
Posts 384
BeoMotion replied on Mon, Jun 29 2015 1:49 PM
Seanie_230:
Yes, of course. Mainly this is just a question of how much effort, money and time you want to put into this.
This "adapter device" should be network capable so that it can read the current source infos from the moment via the BeoRemote protocol.
Then it would be able to translate and inject this information into the PL data cable.
Seanie_230
UK
Posts 2,278
I think i will park this at the "moment" and switch the speakers to Video and live without the display a much cheaper and easier option.
Shame but at least i had a response.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
Hi all
Well after a week or so my moment is now part of the house and doing a perfect Job. It sits with the screen side up as the wooden side is not my cup of tea and will not fit with my decor, this is fine as I lost the pattern play button that's on the wooden side but i just configured one of my essence wall remote buttons in light mode to start pattern play which normally calls up the radio.
I spoke to a dealer yesterday who tells me we may see the wooden part of the moment in the same color as the lab 18's but more than likely wont be retrofit which is a shame.
My penta's have had their displays turned off and my focus now will move to saving for a V1-40 to replace my BV3-32 thats in my Bedroom and not very compatible with the gateway and i am moving NL to be honest. This will mean losing the SD TV in the bedroom so a splitter will be needed for Apple TV and SKY HD but I can live with that.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Chris
Ostend-BE
Posts 1,170
Chris replied on Sun, Jul 5 2015 3:28 PM
Seanie_230:
I find myself more and more using Deezer because its so easy in use.
While I'm reading the Beoforum and some other forum's behind my iMac, I discover new music and add them to a playlist, so easy!
During the day and evening we listen to it on the Moment, its a whole new world opening to us. I never thought I would go the way of online services for our taste of music.
Now with the multiroom update, the Moment has become the centre of our enjoyment in house, almost forgotten to follow Penny Dreadful on TV.
Seanie_230
UK
Posts 2,278
I agree music playing all day today and multiroom is perfect. Only issue I have which was fixed on the ML side is that if I switch on the moment in a ML room the speakers connected to the moment start also and play which is odd but I can live with it.
I wonder what future updates will come.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Millemissen
Flensborg, Denmark
Posts 14,680
@Chris
I guess that was the intention of the makers of the Moment :-)
beoandy
sissi not kangaroo
Posts 329
beoandy replied on Mon, Jul 6 2015 1:08 PM
how does the moment work together with the blgw or the mlgw?
Are the covers/playlist oft the music visible in the beolink app like with the beomaster/beosound5?
BS Ouverture, BS 9000, AV 9000, Avant 32 DVD, BV9, BV6-22, BS 5, BS 4500, BS 7000, BC 9500, Beo6, BL Penta, F1000, BLGW, etc....
Page 1 of 1 (23 items) | RSS
