Why would you angle the wall mount so the speakers point upwards? Is it so the top woofer is flush with the wall?The original manual states that you can mount them both angled or straight but gives no explanation which to choose.I would like to mount my CX's under the ceiling. Any thoughts? I can't find any documentation about where they are designed to be mounted.I know the best height is ear-height. But are they capable of producing good sound "up there"?
