I have the Beogram 8000 from my childhood, but it does not power on.
I just bought an 8002 with MMC 5 on ebay that works for 250 USD. Was just missing the metal tonearm door cover.
Will it be a straight swap? Basically trying to find out if they are the same size.
Thanks.
Adam
The tonearm doors (hinged aluminum plate) are identical.Get them both repaired, they're excellent decks and worth it!
