Hello,I am new here, got myself a B&O 1202 from a second hand shop. The tt looks perfect and is in mint condition. I cleaned the inside and ordered a new belt. The only problem I have now is this https://www.youtube.com/watch?v=iJF3P2yPVwI (not my video)Does somebody know how to fix this, if I move the arm manual a little bit towards the spindle its working fully automatic when I press lift.Do I have to clean the motor?, if so can somebody discribe the dissasembly steps?. And last: can somebody help me getting a service manual?.thanks in advance
you have probably already found the answer yourself by now , but in case you haven't all you have to do is take the tone arm push it past the center bearing until you hear a click this should fix it
