Just moved to a new flat. Had BV-7 55", BV-6 link tv, Beolab 9 and 8000 from before. Sold my BS 5 and upgraded to Moment. Had a installer from my dealer and he did a great job. Everything works perfect and cables are hidden. He also connected aplle tv making BV 7 a smart tv. Had a party on saturday, people loved the Moment. I have nothing bad to say about Moment.
Beovision 7-55" 3D, Beosound 5, Beolab 9, Beolab 8000, Beovision 6, Beo 6, Beoremote one, H8, H2.
Congratulation with a nice setup!
How did he connect Apple tv to the BV7, do you have a hdmi input or did he use hdmi to scart converter?
Do you think the soundquality is better then the BS5
He used hdmi and connected it wifi to AirPort, 52 Mb/s
I haven't had a chance to really sit down alone to analyze the sound quality. But so far I think the sound is more detailed.
gabriel:I have nothing bad to say about Moment.
BeoNut since '75
Yes, a ml-nl converter is used.
I don't quite understand how the Moodwheel works. When I use the inner ring some of my songs appear, a lot without a playlist. If I play a song I find under artist, some appear in the wheel, but still no playlist. Other don't appear there at all.
