Hi, I have just purchased a lovely looking pair of S45.2 speakers (56 Watt). I'm now on the look-out for a suitable Beomaster to buy, but I already own a working Beomaster 1400 and 1600 that have outputs of typically 10 Watt. To test the speakers, would it be OK to connect to one of the above Beomasters? Speaker sensitivity is 5 Watt. I'm just wondering if the amps would be over-strained or something.
cheers
Nick
It would be just fine.And it would sound just fine too.
Many thanks
Most music at listening volume uses about 1W! Moving a big woofer will take more but the S45.2 rolls off quite high.
Peter
Anyone like to recommend a BeoMaster that would match well with the S45.2's?
cheers,
NickNike: Anyone like to recommend a BeoMaster that would match well with the S45.2's?
NickNike:Many thanks Anyone like to recommend a BeoMaster that would match well with the S45.2's? cheers, Nick
Many thanks.
Does the 2200 have touch sensitive controls, for things like volume? I ask as I like the 60's stuff, but there is always the problems of 'scratchy' sounding slider potentiometers. I'm thinking that units with touch sensitive controls will not suffer from worn carbon tracks.
Hi Martin.
My new S45.2's, I purchased off ebay, sound great. The bass is solid, the high frequencies 'sizzle' and the frequency range is reproduced well. It's a very nice even volume on all frequencies.
I read on some other threads that you can supply the capacitors for the cross-over circuits in the speaker boxes. Is it a good idea to change the capacitors generally because of their age, or change them if a deterioration in sound is noticed? If there is a sound deterioration, does it happen slowly over a period of time so the change is difficult to discover, or is there a rapid change and easy to discover?
What's your advise please.
NickNike: Does the 2200 have touch sensitive controls, for things like volume?
