Beolab 8000 no sound
This post has 39 Replies | 6 Followers
Lareny
Down Under
Posts 12
Lareny Posted: Fri, Jul 10 2015 11:28 AM
Hi.
I have a pair of Beolab 8000 speakers connected through a Beolab 2 to my Beosound 5 Encore.
One of the speakers suddenly started dropping out, and when doing so the LEd light turned orange. After a few power off and on and disconnecting power, it went back to working, only to next time do the same.
Now however, it only displays red light in standby and green light when turned on, however NO SOUND!
I thought when green light is on, all is OK, but obviously green light can be on and no sound comes out. I have switched back and forth on cables etc, so I know both outputs on the Beolab 2 are OK, so it is definitely the 8000 that's got a problem.
Any syggestions anyone? Fuses or something else.
This part of the world (UAE) is not the best to get these speakers fixed but if push comes to shove I will pack in my car and drive to Dubai to the dealer.
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Fri, Jul 10 2015 12:15 PM
Foamrot.
SHEFFIELD
Posts 262
SHEFFIELD replied on Fri, Jul 10 2015 6:49 PM
I don't think it will be foam rot. More likely to be power supply or amp module. Will need to go to a service centre though...
Lareny
Down Under
Posts 12
Lareny replied on Sat, Jul 11 2015 3:41 AM
Agreed, foamrot doesn't behave as this does.
Guess it is a trip to the B&O service center.......
Thanks.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Jul 11 2015 8:01 AM
I agree on the foamrot.
The foam in question is not the speaker surrounds, though.
In Beolab 8000 foam is used around cables and circuit boards for anti-rattling and sealing purposes.
Unfortunately, airs moisture attacks and breaks down the foam, which turns acidic and eats
away at copper traces on the circuit boards.
Usually repairable.
Lareny
Down Under
Posts 12
Lareny replied on Sun, Jul 12 2015 7:58 AM
Thanks all. I ended up getting hold of a B&O service tech, so took it to him last evening and will see what he can do.
I thought however when circuits, transformer or power supply goes, the status light would not go from Red to Green. When however it does this, I cannot actually hear the relay turning the speaker on.
Guess I'll get one fixed and the other will go shortly thereafter. Big Smile
Let's see.
Dave Farr
France
Posts 2,283
Dave Farr replied on Sun, Jul 12 2015 10:21 AM
If you can report back to us what the tech says the problem is - it may help others with a similar problem in the future. Dave.
Lareny
Down Under
Posts 12
Lareny replied on Sun, Jul 12 2015 10:30 AM
Will do, let's see if he is any good. In this part of the world I don't have the highest expectations as the quality of tech's in general is somewhat dubious, and then again sometimes surprisingly good, it's a toss of the coin.
I'll hopefully get a call in the next few days with the diagnose, and will post the diagnostics.
Beobuddy
Posts 3,972
Beobuddy replied on Sun, Jul 12 2015 1:15 PM
larseny:
Thanks.
Sorry for the short answer.
Dillen explained it more clearly.
But as I've already had 30+ sets for repair, I recognize the symptoms. I even get the customers who are re-directed (or with highly given posprositions) by B&O service centers..
Depending on the amount of damage caused by the foam, repair is mostly the solution. Replacing the complete amplifier or powersupply section, will result in a pricely invoice.
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Sun, Jul 12 2015 1:37 PM
I'm curious, did B&O change the foam they used at some stage to prevent this issue or is it simply a matter of time before any BL8000 is affected? I dismantled one of my BL8000s last year and the foam seals all looked to be in good condition but perhaps that was just because they are not as old as some.
If this issue is innevitable with time, I'm just wondering whether it might be worth me applying a laquer to the PCBs to help protect them from ths issue in the future?
Martin.
Dillen
Posts 13,191
Dillen replied on Sun, Jul 12 2015 2:08 PM
Beobuddy:
... I even get the customers who are re-directed (or with highly given posprositions) by B&O service centers..
Wink
I don't know if they changed the foam during production, I don't think so, but I can tell you, that
there's a mess inside your speakers now. Particularly in the lower areas where the amplifier, power supply, relais etc. lives and
where cables come in.
It's all a black and sticky mess. I use disposable rubber gloves...
Lareny
Down Under
Posts 12
Lareny replied on Mon, Jul 13 2015 4:51 AM
Sounds like a good old "oops" from B&O's design department............would have thought they had fixed it by now, but mine are older speakers so I am expecting the worst (but hoping the best) and as I said earlier, assume once one is fixed the second will go shortly thereafter.
TTAli
Posts 4
TTAli replied on Mon, Jul 27 2015 1:41 AM
Hi, I have got a pair of Beolab 8000, One is dead, the LED does not come on. After opening it I found the foam as you described, sticky and very dirty. I have cleaned it and started to check what could be wrong. Anyway my question is can the foam be purchased anywhere? for replacement? and do I need it?
Lareny
Down Under
Posts 12
Lareny replied on Mon, Jul 27 2015 5:06 AM
OK, speaker fixed by local tech, solder points corroded and IC board shorted out (obviously due to age and possible foam rot deposited on board). Not cheap, but not too bad. About $150 and it is back in business.
waterlander2004
The Hague, Netherlands
Posts 77
Had the same problem with one of my Beolab800s. Old 'liquified' foam had eaten away a copper track near the side of the PCB. After fixing this, I ordered new foam packages at the local B&O dealer. Worked like a dream (after cleaning up the old mess of course) and was not expensive. Both Beolabs play wonderfully and are ready for hopefully a long period of use again.
TTAli
Posts 4
TTAli replied on Tue, Jul 28 2015 6:49 PM
Thanks for your reply. I cleaned all the mess and found out that everything is in good shape. The wires, Circuit Board, Components all look nice.
But still no LED goes on. Have found the Service manual and trying to figure out where to messure. I am not sure how its trigged on. But the LED shoud be red when the speaker is off I think. Have also checked the fuses and all are good. Maybe i should leave it to the B&O service shop...:-)
Die_Bogener
Posts 192
There is a small Standby transformer. It supplies the standby current for the Relais and the LED.
Whatever done, the red LED must work. If not, the transformer or the fuse or the rectifier etc is dead.
TTAli
Posts 4
TTAli replied on Wed, Jul 29 2015 1:52 PM
Thanks for reply. I checked the small transformer, there is 240V inn but nothing out. So this thing is dead. Any suggestion where to get hold of a New one?
Die_Bogener
Posts 192
The standby transformer has the part number 8013473
I dont know the exact Rating, the standby Transformator has around  2x 18V or 2 x 24V
Maybe 100mA
FlyingNono
Paris
Posts 28
Hi Dillen
Thanks for your explanation, I suspected a problem related to the control standby of my BL8000, with your post I have directly repaired them.
-> command relay, thermistor feed, and some future cracks on a feeder.
Now, I have to change the foam... what kind of replacement can I use ?
Beobuddy:
Wink
For Dillen & Beobuddy, Is it possible to buy genuine parts ?
Regards
Bruno
Many Vintages Lets have a Party !!!
Beobuddy
Posts 3,972
Beobuddy replied on Sun, Jul 31 2016 12:34 PM
For me , it is.
FlyingNono
Paris
Posts 28
Should I translate you by "not for me in Paris" ? Unsure
If it's possible, buy genuine parts is the simpliest way but it's not really relevant for the foam, is it possible to replace it by an equivalent (which is ?)
I will be happy to have a good solution  Wink
Regards
Bruno
Dan
Northeast Pennsylvania, United States
Posts 5
Dan replied on Mon, Jul 3 2017 2:32 AM
Does anyone have pictures or instructions on how to clean or fix? Pictures?
The other question is if this happened to one of your speaker, are you pro active and just do the other speaker also or wait for that to go bad first?
Lareny
Down Under
Posts 12
Lareny replied on Mon, Jul 3 2017 4:45 AM
I guess if there is foam rot short circuiting the IC board and solder post deterioration, it is a matter of whether you want to drag one speaker at a time for repair, or get them both done and over with. I chose the latter, better to be safe than sorry and sitting and listening to your just fixed speaker and then have the other go out. I have an even bigger problem which is maybe why do it now is better than later. I have two pairs of Beolab 5000 active flat panel speakers (the oldie but goodies and beautiful wall art). One has no problems soundwise but displays are dodgy. The others I believe the relays or circuit boards have gone, because they show the light and go click when plugged in, but do not turn on the amps when input is turned on, whether using BEO cables or RCA cables. So, in effect I have a pair of beautiful speakers that will not play (unless I use an outside amp and connect to the bypass inputs for this) and when I took them to the repair shop, first of all the guys could find no documents or schematics for them, so I downloaded them off the net and gave them to them. Secondly and more importantly, and I got this answer from a lady in DK too who is the B&O service manager, "we do not stock parts for speakers older than 13 years", so fu.. me, I am stuck. Anyone have parts - IC boards and/or switching relays for a pair of Beolab 5000's?
Beobuddy
Posts 3,972
You're welcome to send the amps over.
I've overhauled several sets, even some already defective.
I would recommend to send both amplifiers.
marc
netherlands
Posts 78
marc replied on Mon, Jul 3 2017 9:19 AM
I had the same problem a few weeks ago,'
When red and green LED work and no sound, the relais that powers the amp is not working, on 2 occasions the print traces on the bottom of the supply print where corroded of the print due to foamrot, soldered 2 wires to the relais instead of the traces and all was well!
(and replaced the foam!!!!)
FlyingNono
Paris
Posts 28
marc:
Hi Marc,
What kind of foam do you use for this remplacement ?
genuine parts or equivalent with some cut ?
Regards
nono
marc
netherlands
Posts 78
marc replied on Mon, Jul 3 2017 10:26 AM
just bog standard acoustic foam.
FlyingNono
Paris
Posts 28
There are many standard ;-)
I presume you take same kind of grey foam acoustic ?
or is there an acoustic equivalent without risk of degradation ?
Regards
nono
marc
netherlands
Posts 78
marc replied on Mon, Jul 3 2017 10:44 AM
well, the simple gray stuff works fine for me, i do not expect it to liquefy within 20 years, so....  SmileBig Smile
Lareny
Down Under
Posts 12
Lareny replied on Mon, Jul 3 2017 12:34 PM
I would love to, but unfortunately I am currently working in Abu Dhabi in the United Arab Emirates so that would be cost prohibitive to send them.
The local Dubai B&O guys just ran away scared, but one of them suggested it was not the amps, it is either something simple as a fuse or the relay.
frog
Camberley UK
Posts 624
frog replied on Wed, Apr 25 2018 7:59 PM
Good tip from Marc, had the same problem; orange light for a while, so cleaned out the foam. Light went back to red, but no sound, so checked the relay and one track was looking ropey - quick check with a meter confirmed that the track running around the edge of the board was corroded as I was getting no connection between the relay and the connector.
Quick solder of a wire and job done!
tournedos
Finland
Posts 7,357
tournedos replied on Thu, Apr 26 2018 11:21 AM
frog:
Mine had exactly the same problem. The track didn't look corroded though, but the coating of the PCB appeared to have a small scratch near the corner. Perhaps the protective laqcuer had a small imperfection from new, and that was the spot first attacked by the decaying foam.
You should hear the relay click when you plug the speaker into mains.
--mika
IndyBoy1007
Posts 18
Hi I'm awaiting my BL8000s and one of the speakers has had this repair done already however I want to be pro active for the 2nd one and do it myself - what did you use to actually clean out the sticky mess and where can I find out to open the casing?
Thank you in advance!!
new to the game - awaiting my first BL 8000s MK1 Lets have a Party !!!
marc
netherlands
Posts 78
marc replied on Tue, Aug 28 2018 4:44 PM
the foam in the speakers can be vacuumed out with a hoover.
the sticky mess wil disolve in methyl alcohol, dirty job but someone's got to do it!☺☺☺
gerard
Luxembourg
Posts 331
gerard replied on Thu, Aug 30 2018 12:34 PM
Hi IndyBoy
for the removal, take a look at may threat here: https://archivedforum2.beoworld.org/forums/t/34724.aspx
Some help is also provided by the service manual which you can find in the download section here are 3 pictures from it:
The second picture shows 10 screws for the amp modul, but there are only 6 , 2x3 on the borders, as seen in the third picture.
bestbuy1111
Posts 4
My beolab 8000 is purchased in Japan and shipped to Vietnam. It uses 100vol electricity but I plugged wrongly into 220vol. now it is no sound even though the signal light is still turning green when playing music. How to fix it? please help me
bestbuy1111
Posts 4
bestbuy1111
Posts 4
tôiI want to buy
bwest1000
Posts 52
bwest1000 replied on Wed, Nov 18 2020 11:32 PM
Man oh man, I am in this total fiasco.  I have a pair of 8000s that have had a B&O service center voltage conversion - 220 to 110.  They were shipped to me and wouldn't play a sound.  Both lights were orange.  Then I shipped them to a service center who "swore they were working".  Then they're mailed back to me and they're both totally dead.  Nothing.  No red light at all on either.  Nothing.  Totally dead.  The supplier who sent them originally said they worked.  Then they get to me and they dont work.  Then the repair man said they worked and they again dont work. Not even the red light!  What's going on?!?  All parties involved have been very professional, but I am getting frustrated.  Any suggestions?
Page 1 of 1 (40 items) | RSS
