The red Røde caps
This post has 4 Replies | 0 Followers
Christian Christensen
Stockholm
Posts 512
Christian Christensen Posted: Fri, Jul 10 2015 8:56 PM
Have anyone had bad ones be shortened ?
Christian
My re-capped M75 are my precious diamonds.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Jul 10 2015 9:52 PM
They can fail in any way you can think of, - plus a few more.
Shorting is just one of them.
Die_Bogener
Posts 192
Yes, every fail possible.
Shortened, complete dead and open, resistor behaviour, exploded, cracked, acid spreading... whatever you can imagine...
But 30-40 years are a long time... just imagine, what todays Quality will do in 2050?
Stockholm
Posts 512
considering the short distance in the pinout of the rode caps
Which replacements caps do you recommend for the biplor rode caps ?
Die_Bogener
Posts 192
Depends on the capacity... WIMA MKP or MKS types. RM5.
Page 1 of 1 (5 items) | RSS
