Hi,I am trying to find replacement covers for my century. I have dark green now but want bright grey or black. Not been able to find any anywhere. Perhaps I should try to buy new fabric and change the ones I have?
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Beovision 7 40 mk 5 ,beovision 6x3, beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2, 5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
Michael: Hi,I am trying to find replacement covers for my century. I have dark green now but want bright grey or black. Not been able to find any anywhere. Perhaps I should try to buy new fabric and change the ones I have?
If you search the forum, a couple of months ago this was covered by another member who asked about colouring/dying his covers. One member I recall used black toner dye to good effect.
Dave.
Dave Farr: Michael: Hi,I am trying to find replacement covers for my century. I have dark green now but want bright grey or black. Not been able to find any anywhere. Perhaps I should try to buy new fabric and change the ones I have? If you search the forum, a couple of months ago this was covered by another member who asked about colouring/dying his covers. One member I recall used black toner dye to good effect. Dave.
Hi, That was me.
I used some inkjet pigment dye, but beware it never fully really dries. At least it has not on mine. But it is mounted on a wall so not touched.
I was going to use some proper fabric dye, but had some ink spare. From what I see, mixing up some dye and then taking each cover off and submerging it would work too.
The dark green goes black easily.
