Essence Mark 2
This post has 202 Replies | 6 Followers
Millemissen
Flensborg, Denmark
Posts 14,680
Alright!
only way to do it will be connecting the PL-out of the Essence box (in fixed line-mode) to the Aux-in of the BS9000.
This way the Essence will be one single source on your ML-network.
You will have to use the Beomusic-app to control the Essence (choose between its internal sources).
The volume control must be done via the ML-device/s. No need to buy the 'wheely' (the remote) at the moment.
P.S. Your BL2000 must support the Aux-command!
Stan
Chicago-area USA
Posts 869
Stan replied on Tue, Jun 14 2016 8:05 PM
MM describes how to add the Essence to your BS9000.   This probably means they are in the same room and you have no speakers attached to the Essence.
You mention you want it to work like a link room which might be different than MM describes.  If you want to place your Essence in a different room and attach speakers to it, and also play ML sources through your Essence, then you need a ML/NL Converter (BeoLink Converter, BLC).  The BLC will also allow you to play Essence sources through your ML system (assuming you don't already have a BS5, Video Master and Audio Master in your ML system, and Spotify is not allowed to be shared).  You might need an Essence MkII for this.
If you go this route, you also need an iOS device to run the BeoMusic app to select ML sources on the Essence (there is an Android version, but it only controls the Essence, it cannot "see" the ML sources).  The BLC can also have speakers connected to it, and operate similar to a BeoLink Active box (in addition to bridging sources between ML and NL).
Stan
Chris
Ostend-BE
Posts 1,170
Chris replied on Thu, Jan 12 2017 3:36 PM
Is there a button or combination of buttons in using a BEO4 for activating your tv tuner on the V1 television on the Essence II with IR-eye in multiroom?
The V1 is added as supposed in the 'Beolink' page from the Beosetup app. See this link.
Or is this only possible in using the Beoremote One?
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Page 6 of 6 (203 items) « First ... < Previous 2 3 4 5 6 | RSS
