beogram 1203
peter196464
Posts 9
peter196464 Posted: Thu, Jul 23 2015 8:48 AM
hi anybody have the service manual for a 1203 using a rod underneath the lift button instead of a micro switch
have one im fixing and am a bit lost on the rod connections
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Thu, Jul 23 2015 10:20 AM
Upgrade to silver or gold and you can access the service manual on the main site. (Products tag, but go to the service manual link on the bottom of the page before selecting the 1203 from the drop down menu.)
It's a scan of an original manual and does have an exploded view including the rod linkage. Difficult to say whether it will help you though!
Graham
peter196464
Posts 9
do you know what book number it is as i have tryed the manuals ive found but non have the linkage
peter196464
Posts 9
vikinger
Posts 5,422
vikinger replied on Thu, Jul 23 2015 12:50 PM
BG1203/2000 types 5239 and 5240.
Perhaps someone else who has repaired the same 1203 can help.
peter196464
Posts 9
i have that manual but it does not show the set up with no micro switch at the lift button / bar to connect to micro switch at the plater gear / there is no relay box in this set up
i just dont see how to connect into the micro switch at the plater gears
Page 1 of 1 (6 items) | RSS
