Getting CURSOR_SELECT to work for navi mode
This post has 1 Reply | 0 Followers
beojeff
USA
Posts 2,012
beojeff Posted: Sat, Jul 25 2015 6:53 PM
I've recently changed my BeoSystem 3 to navi mode to work with the BeoRemote One. Now, I also need to get my Beo6 to work in navi mode for the BeoSytem 3. I don't want to change to navi mode in the "Choose Products" screen - for fear that I would lose all of my custom editing. Therefore, I'm trying to make the changes on the "Edit" screen. I've gotten the Up, Down, Left, and Right buttons working in navi mode. However, I can't seem to get the Go (or Select) hard button programmed correctly. I have the IR programmed as 0:000:TV:CURSOR_SELECT. I'm not sure whether the "Type" is supposed to be "Beo4" or "Beo5." The problem is that when I press the GO button, it sends out 2 "select" commands when I just need one command sent. Nothing is programmed in the "IR Long" screen. Also, I can't seem to get it to save the setting for having the "Continuous" option ticked. I noticed in a another zone that already was correctly programmed for navi mode that the "Continuous" option was ticked. Can anyone help?
beojeff
USA
Posts 2,012
beojeff replied on Mon, Aug 3 2015 11:34 AM
I was able to achieve this by copying a hard button from another zone and dragging it to the hard button that needed the correct IR code. I had thought that I had read that this feature had been removed; however, it worked.
Page 1 of 1 (2 items) | RSS
