Beosound 3200 volume control problem
jhstitzel
Posts 2
jhstitzel Posted: Mon, Jul 27 2015 7:03 PM
Hi
I am new to the forum and I have no experience with Bang and Olufsen components. I need help.
I purchased a system at an estate sale and have connected a Beosound 3200 to Beolab 8000 speakers using the 8 pin connectors.
I can successfully play a CD, however, I am unable to adjust the volume. Neither of the volume buttons nor the Mute button on the face of the 3200 do anything.
When I try to adjust the volume using the Setup button I get a message that says " Use TV".
I have a remote in which I have installed new batteries but it seems unable to make any connection with the 3200.
I am hoping that someone can give me some advice.
Thanks in advance.
John
sl
Posts 22
sl replied on Mon, Jul 27 2015 8:12 PM
Hi John,
The BeoSound  has three different option
settings:
Option 0. Used in a fully integrated Audio/Video
system with no speakers connected to the
BeoSound . The sound is reproduced
through the speakers in the TV, or through
speakers connected to the TV.
Option 1. Used when the BeoSound is used on its
own or in an Audio/Video integrated setup, with
active speakers connected to the BeoSound (factory setting).
Option 2. Used in a two-room Audio/Video integrated setup.
The programming is done with a Bang &
Olufsen remote control Using a Beo4…
Audio/video setup BEO4:
Hold the ''•'' button down
while pressing LIST
Now let go of both buttons
Press LIST until OPTION? is displayed
Press GO
Press LIST once to display A.OPT
When A.OPT is blinking in the Beo4 display press 1
Regards,
sl
jhstitzel
Posts 2
jhstitzel replied on Mon, Jul 27 2015 11:05 PM
You are awesome!
The house is rocking now!
Thank you so much.
John
Mfg77
Posts 2
Mfg77 replied on Sat, Mar 3 2018 3:50 AM
I have the same issue, but I don’t have a remote, is there a way to do this from the units touchpad? There isn’t a “list” button on the keypad.
Thanks,
Mike
leosgonewild
Helsinki, Finland
Posts 2,373
I have some spares remote if you need one.
Mfg77
Posts 2
Mfg77 replied on Sat, Mar 3 2018 1:22 PM
Thanks, these are the Beo4, right? can you let me know how much you’re asking with shipping to the USA?
Page 1 of 1 (6 items) | RSS
