Volume control Beoplay A9
This post has 12 Replies | 2 Followers
RAXO_CPH
Posts 5
RAXO_CPH Posted: Wed, Aug 5 2015 4:34 PM
Hi, just bought an A9 speaker, but I am quite annoyed that every time it wakes up using the line-in it is at volume setting 60. Is there a way to change the default setting to 80, so that I dont have to open the app and adjust the volume every time I use the speaker?
Br
  • Filed under:
AnalogPlanet
Vienna, Austria
Posts 678
Yes, you can do that in BeoSetup app, under Sound (set default sound level).
Millemissen
Flensborg, Denmark
Posts 14,680
Hi and welcome to Beoworld.
You can change the sensivity of the Line-in connection in the Settings using the BeoSetup app.
RAXO_CPH
Posts 5
I have tried to set the sensitivity to both high and low and changed the default volume to "user defined: 80". But still every time the line-in wakes the A9 it is set to 55-60 (hard to tell cause the number does show until I start moving the control wheel). FYI I am using a Sonos connect to provide the line-in feed. Don't know if that changes anything...
RAXO_CPH
Posts 5
Millemissen
Flensborg, Denmark
Posts 14,680
Is the Sonos set to a fixed line output?
RAXO_CPH
Posts 5
No it is set to variable so I can use the Sonos app to control the volume.
Millemissen
Flensborg, Denmark
Posts 14,680
Then you have two variable volume controls - not the best.
Is this the only way, that you use the A9?
RAXO_CPH
Posts 5
pretty much. Is there a way to set the A9 to volume:80 constantly?
Millemissen
Flensborg, Denmark
Posts 14,680
Not that I know of!
You can set a max level, but that is something different.
I guess 'the makers' did not think of that user case.
Millemissen
Flensborg, Denmark
Posts 14,680
Oh wait - is your A9 a 1. Generation model?
In that case, it might (?) be possible to set a start volumen using a Beo4 (and the Sound Store command).
I am not able to test that myself - maybe someone else could.
Otherweise - contact BeoCare via the B&O website for this information.
AnalogPlanet
Vienna, Austria
Posts 678
Okay now I understand. :)))
My A9 has the same problem, whatever I set as a default sound level (tried with custom:70 and LOUD) it always starts at the level of 55 or so, just like yours.
On top, in new Beosound app volume wheele does not display volume level in numbers anymore. :)
richu
Switzerland
Posts 69
richu replied on Mon, May 11 2020 6:11 PM
Since here are some A9 volume experts, I would like to add my similar question here.
I have an A9 2nd generation. In the setup (web interface or app), I can set the standard default volume. I have to set this at level 50 which is very high (number).
I have also an A6 and a M5. On these two devices I set default volume to 25-35 and I have the feeling, that is almost the same as 50 on the A9. But the A9 is the most expensive and therefore I think it should be a lower number. Now I'm curious if the A9 is dead/faulty? On the BeoVision Avant 55 NG I have default volume at 32. My 20 years B&O experience tell me, that default at around 35 is ok on the devices.
What is you experience? Do you also have to set a higher number on the A9.
Of course, this is very individual - but compare with other B&O devices.
Page 1 of 1 (13 items) | RSS
