Beosound 5 Spotify
This post has 11 Replies | 3 Followers
Razlaw
Posts 4,345
Razlaw Posted: Sun, Aug 9 2015 9:30 PM
Is it possible to select numbered favorites on Spotify on a Beosound 5 with a Beo 4? Similarly, is it possible to use the timer on a connected BV7-55 to activate a numbered favorite of the BS5?
I thought both were possible but can not get either to work.
Thanks.
Frederic
Belgium
Posts 121
Frederic replied on Mon, Aug 10 2015 9:21 AM
Hello,
yes, even the color buttons work. I use spotify on my bs5 all,the time like this. Just add a playlist under a color or a number on your bs5 (like adding a internetradiostation under a preset)
I tried it with a beotime and was able to timer start spotify (amem) and playlist 3 (colors are unfortunately not available in the beotime).
Razlaw
Posts 4,345
Razlaw replied on Mon, Aug 10 2015 12:39 PM
I have playlists created and added to both colors and numbers. But can not activate them with the Beo 4 or the play timer on the BV7.
Razlaw
Posts 4,345
Razlaw replied on Tue, Aug 11 2015 4:33 PM
Am I the only one who has tried or wants to use the Beo 4 and play timer to select a numbered playlist?
How do I do so with the Beo 4? Nothing I try works. Also, regardless of which number I program in the play timer of the BV7, it always starts playing the same thing.
Frederic
Belgium
Posts 121
Frederic replied on Tue, Aug 11 2015 5:43 PM
This is strange.
I have bv7-40 and bs5 as well.
Spotify is set as AMEM on BS5.
i suppose you can activate radio or nradio and cd/nmusic on your Bv7?
i just played around with. Play Timer works but i had to,use CD. MEM as source. I tried channel 1 and 3 ( as in favorite 1 and 3) but as you mention it  started twice the same list i listened to earlier.
however once started i could change it with my beo6/beo4 to the blue list or favorite 2.
did you try Av+"spotify". With my beo6 this pre-programmed but my beo4 I had to go through the av button. My set up is bv7-40 with surround and bs5 with bl4 both in the same room.
are sure your settings,on your bv7 are all correct
mjmedlo
Posts 922
mjmedlo replied on Tue, Aug 11 2015 8:14 PM
I could sell you my master link gateway.
That'd do it!
Razlaw
Posts 4,345
Razlaw replied on Tue, Aug 11 2015 10:08 PM
Frederic:
This is strange.
Thanks! I am pretty sure all settings are correct. Could you explain exactly what sequence of buttons you press to select 2 on your Beo 4?
Razlaw
Posts 4,345
Razlaw replied on Tue, Aug 11 2015 10:09 PM
mjmedlo:
That'd do it!
I have thought about a MLGW, but get totally confused when I read about it.
Frederic
Belgium
Posts 121
Frederic replied on Tue, Aug 11 2015 10:29 PM
with beo4:On the bs5 and in every linkroom: AMEM and then 2 when I hear that the music has started.
on my bv7 i have to press av amem
i just tried it even with a BL1000: ATAPE works perfect, can't select the colors though :-)
In my case on the BS5, under settings>roles>music services is set as AMEM
Razlaw
Posts 4,345
Razlaw replied on Wed, Aug 12 2015 1:13 AM
Frederic:
I changed the settings to A. mem. Seems to work with the Beo 4, but the BV7 play timer does not have A. Mem as an option. V. mem and CD Mem are present.
Frederic
Belgium
Posts 121
Frederic replied on Wed, Aug 12 2015 11:03 AM
Correct, as I mentioned. BV7 (even my bv6) only has CDMEM as source. ATAPE, AMEM and CDMEM are the same ML commend. If I'm right cdmem was introduced when the BS3200 had the harddisk and replaced the cassette.
what I noticed as well that whatever number you enter in play timer spotifiy starts with my red list (maybe being the first saved playlist) so if you want to be awakened with a certain song put it in the beginning of the red list.
Other cheapest solution if you still can find one is a beotime if you want to start another playlist, expensive solution mlgateway
Razlaw
Posts 4,345
Razlaw replied on Wed, Aug 12 2015 1:41 PM
Frederic:
Thanks for all of the information and assistance. I guess it just is not possible to use the play timer to select a playlist. I have a Beotime. But it is not practical for starting something every day. The alarm sounds and then has to be turned off. Easier to just turn on at the BS5 or with the Beo 4.
Page 1 of 1 (12 items) | RSS
