Moment on V1
This post has 11 Replies | 3 Followers
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Sat, Aug 15 2015 12:04 PM
Hello all when playing music on my v1 over NL it works perfectly.
Annoying point is that the screen keeps turning blank after a few mins and I like to see what is playing.
I'm sure I turned off Eco thing but it still does it
Any advice :)
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Sat, Aug 15 2015 3:21 PM
Hi Seanie
Go to your V1 and "Join" to start music playing from your Moment.
Press menu to show your Source list.
Highlight the source that is playing and press "RED" to access the set up menu.
Select ADVANCED SETTINGS
Select PICTURE OFF. From here you can choose: TIMEOUT, ALWAYS or NEVER.
Press middle of star button to store.
This setting only applies for this source.
Regards
Opman
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Sat, Aug 15 2015 3:27 PM
Hi Seanie
On your V1 select music from the Moment (join)
Press Menu and select Source List.
Highlight the nsource that is playing and press RED button to access the set up for that source.
Select ADVANCED SETTINGS.
Scroll down to PICTURE OFF.
Right arrow you to choose from: TIMEOUT,ALWAYS or NEVER.
Press GO to store.
Regards
Opman
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Sat, Aug 15 2015 3:28 PM
Hi Seanie
I have replied with a solution and "broken my duck", first ever post that requires moderation. Watch this space.
Regards
Opman
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Sat, Aug 15 2015 3:42 PM
Hi Seanie
In case you can't wait for my post to be moderated, I have emailed you a solution.
Regards
Opman
Millemissen
Flensborg, Denmark
Posts 14,680
In case it does not turn up, could you repeat, what you wrote....
....in a more 'moderator-friendly' way ;-)))))
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Sat, Aug 15 2015 5:01 PM
Millemissen:
I am intrigued as to how to not trigger the need for moderation. I simply typed out a step by step sequence of how to solve the problem. There was no ambiguity or dubious words. If I type it all again, I don't know how to get around the moderation issue.
Hopefully it will appear in due course.
Regards
Opman
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Sat, Aug 15 2015 5:06 PM
Normal 0 false false false EN-GB X-NONE X-NONE
Switch on V1 and initiate music from Moment (JOIN)
Press Menu and select Source list. This should highlight the Music from the Moment.
Press RED to access the “set up” feature.
Scroll down to PICTURE OFF and press right arrow.
Select from: TIMEOUT, ALWAYS or NEVER.
NEVER means the picture NEVER turns off.
Press GO to store.
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Sat, Aug 15 2015 5:13 PM
Millemissen:
Hi MM
As requested I posted here again and it didn't appear. I have also started a new thread with the explanation but this is now also pending moderation. Suddenly after all these years I appear to be deemed unsuitable.
I bet Apple woouldn't treat me like this ha ha. Takes out pin and retires to a safe distance. Whistle
Opman
Bv7Mk3
uk
Posts 781
Bv7Mk3 replied on Sat, Aug 15 2015 6:17 PM
Like your Style!
Chris
Ostend-BE
Posts 1,170
Chris replied on Sun, Aug 16 2015 9:02 AM
Interesting subject, I wonder what is the difference on the V1 between the setting 'always' and if you do 'p.mute' on your list.
With 'p.mute' the curtain closes, is the screen in this case completely off or is it just a beauty detail to view. Are in both cases the screen completely off-powered, or is it just the lamp off-powered what seems to happen immediately if you use the setting 'always' in the menu.
Asked this question on the other thread, but its waiting approval from a moderator Sad
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Seanie_230
UK
Posts 2,278
Hi there
This worked perfectly
Thank you
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Page 1 of 1 (12 items) | RSS
