Beovision 8 as slave TV ML clock issues.
Jackplug
Posts 40
Jackplug Posted: Sun, Jun 17 2012 1:23 PM
Hi, I've posted something before on this but think I made the problem description so complicated that I never got an answer.  So basic problem, when I connect a Beovision 8-32 to my ML network (TV is set to OPT 6 slave in the bedroom),  as soon as I do this, the ML clock for the whole network (provided by a BS9000) is reset to 0:00.  If left this way, the clock runs ok for a few hours but keeps resetting.  Once I take the Beovision 8 off the link system and reset the clock to the right time, it stays accurate until then next time the Beovision is connected.   Why is this SLAVE TV having an effect on the master clock from the BS9000?   I need the BS9000 to be in option 0 in its current location but I have tried it set to option 1 and still get the problem with SLAVE TV messing up the clock?  Is there a known issue with BV8 ML software or something?
expoman
Posts 182
Silver Member
expoman replied on Sun, Jun 17 2012 3:49 PM
What other products are on the ML line?
Did the BV* get the software update for the ML board?
Jackplug
Posts 40
Jackplug replied on Sun, Jun 17 2012 5:30 PM
Other things on the ML are, BV10-40 set to option 2, BL3500 set to link option 6 and a Beomedia 1.  There's a Beolink Active for the Pentas and a passive for some other speakers.  All these other units are always connected and don't obviously have an internal clock (including the 10-40 which I find crazy).  Is the ML s/w update for the BV8 a dealer visit thing?  Will check the version and see what it is but it's 2009 model?
Page 1 of 1 (3 items) | RSS
