Beocenter 2 with beovision 4/Beosystem 2
This post has 3 Replies | 0 Followers
mayface
Posts 37
mayface Posted: Sun, Jun 17 2012 2:57 PM
I have a bv 4 and bc2 masterlinked together - speakers plugged into beosystem 2, i get tv and dvd sound but the speakers do not come on when pressing cd or radio, i guess its an option issue or i do recall the powerlinks may need switching on/off on the beocenter 2.
Any ideas?
Regards,
Darren
KingOfSnake
Posts 162
Darren, bit surprised to see you asking this as a Specialist!
TV V.OPT 2 BC2 A.OPT 0
On some BC2's DVD operates the drive if a CD is in the drive - have you got an aerial plugged into the socket unit?  If not it will auto-mute.
mayface
Posts 37
mayface replied on Sun, Jun 17 2012 7:43 PM
Hi Specialist,
Did that, didnt work, hence my question....
KingOfSnake
Posts 162
You thought it was an option issue - so these are the correct option settings.
A dvd plays when you press dvd but a cd does not play when you press dvd?
Is a scart connected between bc2 socket and bsys2? Defo aerial plugged into bc2 socket?
go into setup menu and check whether there is option to disable radio
I would have thought A.opt 0 would have defaulted sound to TV, try the pl on/off.................. or did you do that already and it didn't work? :)
Page 1 of 1 (4 items) | RSS
DigiCert Secured Site Seal
