Hi!I am in the process of renovating my Beovox 2400and am trying to find some electrolytic capacitors.The specs for what i am looking for are:WiconElectrolytic CapacitorFor cross over75 μF 25 V.PeakType ECI 752BipolarAUXAre there anyone who know where i can get some of them:Or any place that sells them or something equivalent it would be nice to know =)Thanks!
If you cant find the correct one, then put 2 in parallel like 1, 33 uF and a 47 uF = 80 uF is within the 20 % limit, can be Axial or Radial no problem. Voltage can be 25, 35 or 50 V, try Mouser or Parts Express
And welcome to the forum
Thanks =)
Ideally i would like to find a single Capacitor like the original, but if i have to be creative thats life =)
Thanks for the company suggestions =)
Falcon Acoustics has 75 uF electrolytics in stock!
Jacques
Hmm, i can't seem to find them, do you have a direct link?
Oh, they used to stock them, sorry!
There.
http://www.cricklewoodelectronics.com/CAB72.html
