Hello to all, I need to upgrade the software of my Beovision 7 to work with my new satellite box can any one tell me please how I can do it ???
Hi there
Modern bang and olufsen tv's have a PUC table that needs to be flashed by a dealer, the will build you a table that has the devices you want.
Each new update deletes the old table so get as many installed as you can think of.
Good luck
Eclipse 65V1-32Beosound M5Essence MK2BLI
Thanks for your reply very kind.
