What do you guys recommend (if anything) to clean/polish the chrome panels on a Beomaster 4500?
I was thinking I might spiff my Beomaster 4500 up a bit with chrome polish, however if B&O used a plastic sealant on their chrome, chrome polish would be a disaster.
Deciding to err on the side of caution I thought I better ask BEFORE attempting this polishing.
Jeff
Beogram 4000, Beogram 4002, Beogram 4004, Beogram 8000, Beogram 8002, Beogram 1602. Beogram 4500 CD player, B&O CDX player, Beocord 4500, Beocord 5000 T4716, Beocord 5000 T4716, Beocord 5000 T4716, Beocord 8004, Beocord 9000, Beomaster 1000, Beomaster 1600, Beomaster 2400.2, Beomaster 2400.2, Beomaster 4400, Beomaster 4500, Beolab 5000, Beomaster 5000, BeoCenter 9000. BeoSound Century, S-45.2, S-45.2, S-75, S-75, M-75, M-100, MC 120.2 speakers; B&O Illuminated Sign (with crown & red logo). B&O grey & black Illuminated Sign, B&O black Plexiglas dealer sign, B&O ash tray, B&O (Orrefors) dealer award vase, B&O Beotime Clock. Navy blue B&O baseball cap, B&O T-shirt X2, B&O black ball point pen, B&O Retail Management Binder
Exactly where many owners go wrong.It's NOT chrome. It's aluminium polished to an extreme shine.Abrasives is generally a no-go on this soft material. Almost anything you do will make it dull and grey.
Why thank you Martin, you just saved me a whole lot of unnecessary aggravation. I am a big fan of Simi-Chrome polish, a German product that is truly amazing on many metals including aluminum with a dull finish.
However the jeweller in me knows that polished aluminum is entirely a different matter, the chrome polish is an abrasive, as you noted, and would have made countless scratches on the surface area.
Again, as a jeweller, I do have polishing equipment that “could” polish the soft aluminum panels, but my set-up is for small pieces, larger items like the B&O panels are difficult to do with wheels that are too small and the exhaust hood getting in the way.
B&O would have used large polishing wheels on a flat surface, so I am “wisely” going to leave well enough alone.
Thank you again for the most appreciated education.
Hi Rich,
Windex should do a good job with either, but I strongly recommend using the clear (as opposed to blue) Windex with vinegar as it is more gentle than the blue based with ammonia.
The polished aluminum should not react negatively to the clear Windex. I have used it regularly on my Beomaster 4500 and Beogram 4500 CD player for years. This cleaning has been a required regular process as both Beomaster & Beogram live in the kitchen.
Just recently I FINALLY smartened up and covered both with a heavy soft towel while dinner is being prepared. Cut my Windex cleaning down to next to nothing, at least in regard to the BM 4500/BG 4500.
The Windex with Vinegar can also be used with light coloured fabrics and carpeting. You can’t do that with the blue variety as it leaves a blue stain.
Hey Rich,
I just re-read your post and you specifically said touch-panels. Sorry about that, however the Windex DEFINITELY with do a superb job on the touch-panels.
The only thing is you HAVE to pull the power plug first as you can not clean without driving the units nuts. I’ve tried to clean carefully avoiding the contact buttons, but trust me; it is a waste of time as you won’t get the units properly clean that way.
Just unplug the Beocord 4500 (the CDX has a power button) clean it and then plug it back in the wall socket.
Now while you are cleaning the touch panels you can also clean the polished aluminum.
