Beogram 2200 Type 5721 Stop-function not working
ALF
AUS
Posts 1,015
Silver Member
ALF Posted: Tue, Aug 25 2015 10:43 AM
Greetings all,
I must be sitting on my brain but I can work out that 'Stop' function on that turntable.
Every other function works as should but 'Stop' doesn't seem to do a thing ??
What am I missing here ? Which components are most likely-suspects ?
I  checked various caps and diodes, changed TR11 but no impact.
Anyone any good ideas ?? I wonder whether section 'b' of 15RL1 gets enough voltage ?
Simply put: i am stuck at the moment, so your ideas are most appreciated
Cheers,  ALF
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Aug 25 2015 3:11 PM
These decks are known to develop oxdiation inside the front panel contacts, particularly if not used for a long time.
The STOP button is not one of the most used buttons, so I suggest you try using a little "controlled fingerforce" and
press it a little harder than you normally would 15-20 times and see if you can break through the oxidation.
If not, it needs taking apart and cleaning.
ALF
AUS
Posts 1,015
Silver Member
ALF replied on Wed, Aug 26 2015 6:16 AM
Many thanks for the advice Martin :-)
Under normal circumstances an easy job but someone was so clever and clued that control board, meaning I won't be able to do some cleaning - great !!!!
perfectly logical that the Stop button won't be used very often and I guess I could live
With the Pause function with the additional 'job' of moving the arm into its resting position - big deal :-):-)
Will however try to apply some contact-cleaner-spray through the gaps with the hope some finds its way onto the contact surface ??!!
Only need a tiny cleaned area:-)
Cheers - ALF
ALF
AUS
Posts 1,015
Silver Member
ALF replied on Wed, Aug 26 2015 9:43 AM
I tried the contact cleaner but without any luck !
As I can not have access to the switch I may have to leave it there unless
There is another dead component involved on the board 1 ???
Cheers, ALF
Page 1 of 1 (4 items) | RSS
