Hi anyone knows how to setup the Avant 55" and Xbox One? I have the cable and tried the two Xbox and Xbox 360 that I find when searching online from TV setup but those won't work. Has anyone been able to get the beoremote one to work with Xbox one?
A little bit unrelated, i know my PS4 doesn't work with my Avant, so i would guess the Xbox1 would be the same? I don't mind using my PS4 controller as I will use it anyway for a game.
Does it (xbox1) also have a bluetooth remote?
Thanks but I don't think it has a Bluetooth receiver. The reason I want to use the Beo remote it because I use the Xbox as a Blu-ray player for movies.
Hi there! I don't have any idea about the setup. You may search online or read articles on it about the setup. I don't use one, but my friend recently bought Xbox Live for Live TV and online games. He uses be remote from his Xbox one. Find out more information online.
The Xbox one code does indeed work on the Avant 55 series. You will need to position the ir around the eject button about a half-inch from the Xbox itself, not on the Xbox. it should work from there.
Ah, you know... A little B&O here, a little there
