Beomaster 3000 problems
gbolt30
Posts 2
gbolt30 Posted: Sat, Aug 29 2015 5:44 PM
I have a Beomaster 3000 that I bought new in the 80s.  I love it.  But it is starting to show its age.  The sound on our Speakers 2 line is starting to cut out.  But more troubling is the fact that the unit has spontaneously turned itself on a couple of times.  I don't use the radio on it, but when it turns itself on it is always on a radio station and it is about midway up the volume scale.  Is there some simple home servicing/cleaning that I might try or should I have it serviced?
Die_Bogener
Posts 192
Sounds like a dead lithium cell on the cpu board. If less than 3V there are memory problems.
3 Euro material and 30 minutes work.
gbolt30
Posts 2
gbolt30 replied on Sat, Aug 29 2015 10:18 PM
Thank you!
Page 1 of 1 (3 items) | RSS
