I recently putchased a Beocom 6000 with a PSTN base station (I think that is what is called, the black box which let you have the phone on another place then where you have the telephone jack).
Anyway, I am a little lost with the setup, I would like to erase everything and start from scratch but I am not sure how to do it. I tried to erase the Beocom but after I connected it again to the base everything came back.
So, should I ersse the base, then erase the Beocom and then pair them?
Best regards,
Riven
My B&O products: Beosound 9000, Beosound 2300, Beosound Century, Beolab 8000, Beolab 6000, Beolab 4000 x2, Beolab 3500, Beolab 2000, Beolab 10, Beolink Active x2, Beotime, Beo5 x2, Beo4, A9 keyring x2, LC2 dimmer x6 and growing....
Rivenflush: So, should I ersse the base, then erase the Beocom and then pair them?
In short, yes! The numbers are stored in the base (unless you have the phonebook set to private) so clearing the base should clear all the entries. You may have a PIN code set, but try the default which is 0000. I think that the manual is available on site.
