Can I use a BeoVision 7-32 Type 4097 motorised Floorstand with a BeoCenter 6-26
This post has 4 Replies | 0 Followers
kallasr
Germany
Posts 2,562
kallasr Posted: Tue, Sep 1 2015 11:17 AM
I know the number in the pricelists says Type 4098 is for a BeoCenter 6-26.
But since both share the same motorised table stand Type 4092 I assue the wiring is the same.
So what is the difference between 7-32 and 6-26 Version of the motorised Floor stand - maybe the possibility to attach a Beolab 7 Speaker to the 7-32 Type 4097 Version?
Thanks for any hint
Ralf
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Wed, Sep 2 2015 10:20 AM
Hi Ralf
From my experience the motor floor stands for the BeoVision 6 26" and BeoVision 7 32" are interchangeable. You are correct to identify that the different type number refers to the pole of the BeoVision 6 26" version not having the holes to affix the plate for a BeoLab 7 loudspeaker.
The bracket that holds the set and the din plug are the same.
Regards
Opman
9 LEE
Eastbourne, UK
Posts 7,218
What that man said above is completely correct. Smile
kallasr
Germany
Posts 2,562
kallasr replied on Wed, Sep 2 2015 11:49 AM
Thanks to both of you!
Ralf
julefreund
Posts 317
Hello Ralf,
additional to the mounting screws for the beolab 7 the florstand for the BV 7-32 is a little bit higher ( about 15 mm ) than the florstand  for the BV6-26.  I use my BC6-26 with florstand of the BV7-32. Works perfectly.
julefreund
Page 1 of 1 (5 items) | RSS
