If they are paired by Bluetooth you can have one as L and the other as R. Now, if you add a transmitter to the equation, I suspect it may mess that up a bit. I've just orderd a Bluetooth receiver to try to put on my Beolit 12 as Airplay is so useless with it. I'm trying to convert it to a Bluetooth Beolit 12 via the line-in and put the receiver behind the cable/socket storage flap (only 15€ for the receiver). I've no idea if it will work or not. I'll let you know because if I can select what it pairs to, you should be able to do something with the Beolit 15.
Have you tried asking B&O customer support?
Dave.
