Where to buy 8 Din extension cables for Beolab 8000?
djhayes2004
Posts 10
djhayes2004 Posted: Fri, Sep 4 2015 5:01 AM
2 approaches here:
1. I need 8 Din extension cables for my pair of Beolab 8000 approx. 50ft - any recommendations on where to buy? i cant find anything that long on ebay.
2. Is there a cost effective way to make the speakers wirelessly connect to my beomaster 7000 receiver (the B&O connect stuff is cost prohibitive)?
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Sep 4 2015 6:17 AM
The obvious answer is, look down this very page!
Jacques
Dave Farr
France
Posts 2,283
As Jacques has said, Steve at Sounds Heavenly is the Man.  You may also need a Powerlink connector.
In theory, you could try a Bluetooth transmitter from your BM7000 and a receiver at the line in of the BL8000.  I haven't tried it and I don't know how the quality would be.  It would probably be better to daisy chain the BL8000's then.
Dave.
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Sep 14 2015 8:02 AM
I've tried the Bluetooth thingy. It produces too much noise (hiss) with the Beolabs.
Jacques
stefan
200 miles from Struer
Posts 2,920
stefan replied on Mon, Sep 14 2015 3:00 PM
djhayes2004:
2 approaches here:
I recommend to buy a (one!) long Powerlink cable, you will only need the thin cable with 3 wires and ground for BL8000, install it to the "first" BL8000
connect an y-cable to the second 8000. One PL cable handles both channels - left and right, so no need to get two long cables.
You can get PL cable from your dealer in black or white and 7 or 8 pin DIN plugs are available from your dealer too or in most electronic stores.
It`s not that difficult to solder - wiring diagram should be on the beotech site.
Stefan
djhayes2004
Posts 10
Thanks guys,
i ordered a 20M cable from Soundsheavenly so i think i should be sorted!
Have any of your guys augmented a Sonos system in the mix? it seems like its still the best/most cost effective multiroom solution.
Page 1 of 1 (6 items) | RSS
