mjmedlo: Razlaw: Sound in one room? Both rooms? Nothing? Will I need to turn system n in one of the rooms with the Beo 4 and join the Moment so a two step process? The speakers connected to the moment will start Otherwise nothing else. See the moment just like you see your BS5. It's a source that you start then join others to. In your scenario, you'll name v.aux2 for instance as tune in on the NL/ml converter. Then when you start radio on the moment and select v.aux2 on an ML product.... You'll have tuneIn. Hope this helps.
Hope this helps.
Thanks! It would be slightly different than the Beosound 5. If I select a source directly on the Beosound 5, it turns on the speakers connected to the TV that is identified as the Video Master. So with no speakers connected directly to the Moment, I would not be able to turn anything on from the Moment?Would the volume wheel on the wood work once the speakers were playing?
Razlaw:May just have to take advantage of dealer's 30 day return policy and order and see how it works. Thanks for all of the input and assistance.
I am still having a difficult time grasping how my system would work with a Moment or an Essence.
I have a BV7 and BV10 and BS5 connected by Masterlink. I also have a stand alone V1
If I purchase an Essence and one converter, would I be able to Press a button on the Beo 4 to turn on Spotify from the Essence in the room I am in and have it play through the TV's connected speakers just as with my BS5, but then with the added benefit of being able to use the app to search for and select music?
Same question with a Moment and Deezer?
Thanks!
Razlaw:I am still having a difficult time grasping how my system would work with a Moment or an Essence. I have a BV7 and BV10 and BS5 connected by Masterlink. I also have a stand alone V1 If I purchase an Essence and one converter, would I be able to Press a button on the Beo 4 to turn on Spotify from the Essence in the room I am in and have it play through the TV's connected speakers just as with my BS5, but then with the added benefit of being able to use the app to search for and select music? Same question with a Moment and Deezer? Thanks!
mjmedlo:Spotify is analog on bs5 Digital on essence mark 2 If ou want spotify distributed.. Connect an essence mk1 to your line in on BS5 and distribute away!
