beomaster 6500 to poweramp
This post has 2 Replies | 2 Followers
PHILIPPE51
Posts 1
PHILIPPE51 Posted: Sat, Sep 19 2015 4:12 PM
i would like to connect a beomaster 6500 to a surround sound amp
i noticed the DIN output line in-out on the back panel
so i thought plugging in a din to cinch cable ,but i had a cable with only 2 cinch outputs
and it didn't work
do i need to have a cable with 1 din and 4 cinch ends ?
and will it work than?
grts  Philippe
ProGram
59269 Beckum, Germany
Posts 383
ProGram replied on Sat, Sep 19 2015 7:46 PM
Hi Philippe,
PHILIPPE51:
Normally, there should be a plastic "dummy" plug, which connects in and out. This plug contains two bridges, one for each channel. The in-out-socket is designed to use an equalizer or other sound equipment. Maybe in your case, you must use a 4-cable adapter and connect the "record" outputs with the "play" inputs (or a sourround, what you like)
Chris
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi Philippe,
Please don't worry, you don't need to use the Line In-Out connector, you can simply connect the 6500 to the RCA inputs of your power amp using one of the Powerlink sockets on the 6500 via this cable to give sound with volume control from the B&O remote:-
http://soundsheavenly.com/bang-olufsen/110-5-pin-din-to-twin-rca-powerlink-compatible-to-non-bo-hifi-amplifier-receiver-etc-din-to-twin-phono.html
If you need any further help, please feel free to ask.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (3 items) | RSS
