Hi!
The beosound essence mk1 is a networklink product, right? So it should appear in the mlgw networklink product assignment or not?
Normal 0 21 false false false DE JA X-NONE
beoandy
BS Ouverture, BS 9000, AV 9000, Avant 32 DVD, BV9, BV6-22, BS 5, BS 4500, BS 7000, BC 9500, Beo6, BL Penta, F1000, BLGW, etc....
Not!
Hi mm
Okay, this was quick and short
Is this a mlgw/blgw thing or is the essence mk1 not a networklink product?
The mk1 is not a netlink product, unfortunately it will not be updated so is just stand alone.
regards
okay! thanks for the response!
