Beosound Essence Mk2
This post has 27 Replies | 1 Follower
Rudi Pedersen
Herning, Denmark
Posts 125
Rudi Pedersen Posted: Fri, Sep 25 2015 12:02 PM
Hi
I have upgraded all my link rooms to Beosound Essence Mk2
Does anyone know how to set like bass, treble and mono/stereo ??
The Setup app has none section for this.
I have asked the Support in Struer 3 times now, but gets no response at all (very bad support !)
Best regards Rudi
Dave Farr
France
Posts 2,283
Dave Farr replied on Fri, Sep 25 2015 12:21 PM
Rudi, who have you tried to contact? My experience is that when you contact the correct department, you get a very fast response and help. Have you tried your dealer?
I would have thought changes to these settings would be done via your streaming source (Deezer, Spotify etc.) which is where I do it for my A9 etc. I'm not sure you can do this directly as an Essence string.
Dave.
Rudi Pedersen
Herning, Denmark
Posts 125
Hi Dave
It is sent to bogo@mailgb.custhelp.com, the mail address that responded to my request at the web.
br Rudi
petrosbeli
Posts 64
petrosbeli replied on Fri, Sep 25 2015 10:55 PM
Hi Rudi,
at this phase the BeoSound Essence does not have any options/settings for manually configuring the bass, treble, etc...
Br,
Petros
Millemissen
Flensborg, Denmark
Posts 14,680
Best use the webmail on the B&O website - costumer service -> contact.
How do you know the mailadress, when you did not get response❓
Did you ask your dealer the same question?
Dave Farr
France
Posts 2,283
Dave Farr replied on Fri, Sep 25 2015 10:59 PM
As I said though, my understanding is that you need to do this via your source, not the Essence.
Dave.
Millemissen
Flensborg, Denmark
Posts 14,680
I would not be surpriced, if it can be done by connecting an ir-eye to the unit using the beoremote.
Rudi Pedersen
Herning, Denmark
Posts 125
I did use the web - the mail was shown in the auto response
Rudi Pedersen
Herning, Denmark
Posts 125
Well, the source is the Essence
Dave Farr
France
Posts 2,283
Dave Farr replied on Sat, Sep 26 2015 7:12 PM
OK, I'll rephrase - from the control device that you use e.g an iPhone, iPad etc. you can change all settings from there, my understanding is the Essence per se can't do that.
Dave.
sia
Posts 48
sia replied on Wed, Nov 4 2015 3:47 PM
I wonder why B&O has not included WISA in Essence MK2. After all it seems that all new B&O  speakers have WISA so why not making new devices compatible with them?
Upgrading the essence with Beolab Transmitter 1 also seems to be overkill if you are only using the audio source (which esence is) and all newer TV's already have WISA-capabilities.
Could it be so that several WISA-transmitters could not be installed in the same home due to interference?
are there any two channel WISA-transmitters out there?
Millemissen
Flensborg, Denmark
Posts 14,680
Why force people to pay almost double-up, when they don't need the WiSA function?
If you need it, just buy the Transmitter 1 - easy, peasy 🍋
sia
Posts 48
sia replied on Wed, Nov 4 2015 4:32 PM
Millemissen, it however seems like B&O designers thought differently with regard to the speakers as they already have wisa receivers and everyone have to pay for it, even if they might rather use powerlink cables and save a few bucks.
StUrrock
Posts 995
Millemissen:
with a mess of wires!
sia
Posts 48
sia replied on Wed, Nov 4 2015 9:03 PM
I would have gladly paid for wisa-capabilities in Beosound Essence.
StUrrock
Posts 995
Second most important Audio product without WISA.
Maybe there are idiots living, designing and working in Denmark?
Millemissen
Flensborg, Denmark
Posts 14,680
StUrrock:
Well, well...
Who did rain on your parade?
StUrrock
Posts 995
Millemissen:
Well, well...
Nobody rained on my parade.
I was just asking a question?
Millemissen
Flensborg, Denmark
Posts 14,680
In that case, I would answer with a 'no'!
But where is the 'link' to BS Essence MK2/second most important Audio product/WiSA?
elephant
AU
Posts 8,219
sia:
Yes - thumbs up
BeoNut since '75
Rudi Pedersen
Herning, Denmark
Posts 125
Finally the software is upgraded with sound control ....works well...
Millemissen
Flensborg, Denmark
Posts 14,680
What is the version of your Essence software?
Mine is: 1.8.480.215239933 (as of 18. Nov 2016)
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Sat, Nov 19 2016 6:36 AM
Millemissen:
Hi MM,
Yes, that is the new version with support for bass / treble / loudness controls. The sound controls are accessed via the beosetup app under 'sound' -> 'sound controls'.
Martin.
elephant
AU
Posts 8,219
elephant replied on Sat, Nov 19 2016 10:02 AM
riverstyx:
Hi MM,
Martin.
BeoNut since '75
Aussie Michael
Melbourne, AU
Posts 3,730
Millemissen:
Same as mine
zerocool143
Posts 94
Rudi Pedersen:
Hi
Best regards Rudi
The Latest update of the play products will enable the ability to adjust the treble and bass.
Try to update your Essence and see if that will have also the same feature of the latest software update.
Sal
California, USA
Posts 1,197
Sal replied on Wed, Nov 23 2016 1:42 PM
I just checked my Essence through the BeoSetup App and lo and behold here's a sound control option in settings / sound which has bass tone, treble and loudness options.
Millemissen
Flensborg, Denmark
Posts 14,680
....and the option to pick out the exact kind of speakers, that you have connected.
Page 1 of 1 (28 items) | RSS
