I've got a problem with my Beolab 18 Speaker. I tried to connect my new Moment and I pressed the reset button. And after the reset the LED is flashing organge quickly?
What can I do now? Anybody a hint for me?
Thank you
Mirco
Thank you for your answer. I looked into the manual an find the text above.
My Beolab is blinking fast and tommorw I will ask my dealer for help.
Thought, anbody has a Tip for me,..
It was a software problem and the Beolab will get new Software :-(
