Dear BeoWorld members,
I have a full 4500 system that I purchased new in 1992. It is flawless - no scratches or dings. Unfortunately, it's quite dirty from being in storage a long time. The mirrored surfaces are caked with dust, and the red touch panels are dusty too. I think at one time, someone must have licked their finger to try and remove a smudge, so they have some swirls as well. That said, I'm positive the surfaces underneath are flawless.
What would be the best way to lean up these surfaces without causing any harm? I imagine the mirrored ones would be easy, but I don't want to try and clean the touch panels without knowing exactly what to do and what to use first.
Thanks so much...
Thank you very much. They have actually been on display, just not used, for years. So there have been no climate or exposure issues. They just need to be cleaned. I of course made the mistake once of using a wet finger to test the process, and noticed how easily the surfaces streaked. I'm quite certain though that there is no damage or wear. Are the red touch panels truly glass, or are they covered with some sort of film? If they're glass, I'll feel much more comfortable about cleaning them. I've always been worried though that there was perhaps a plastic film overlying the glass.
That sounds great - thank you so much. I've used these (http://weiman.com/Products/Electronics/E-Tronic-Wipes.aspx) on my more ordinary equipment, but have never tried them on anything as upscale as my B&O components. Do you think they would be ok? What I like is that they're moist enough to loosen dust, but don't streak as the surface dries. Not sure if they could cause harm though. Thanks again.
Unfortunately, they will not tell you what is in these sp you don't know if the ingredients will be harmful or not. The only way would be to try one on a very small area first. I'd stick with the easy option of detergent and water. In theory, they should be OK as they are designed for use on screens etc. Depends how brave you are?
Because the metal has a coating, you won't know if the ingredients react with it - make it dull for example?
Dave.
Agreed. Is there any sort of specific detergent you recommend? Sorry for all the questions...
