What are these dark spots on BV7?
This post has 13 Replies | 1 Follower
DrDimitris
Greece
Posts 699
DrDimitris Posted: Thu, Jun 21 2012 7:42 AM
Hi all. Recently i noticed some brownish spots around the center of the screen of my 2006 BV7-32. I do not think it is clouding because it does not appear on dark scenes. It is only visible on very white/ light grey/ light blue scenes, like snow, clear sky, sea. I am feeding my HD-Ready TV with HD Sat and Blu-rays. It is independent of the source. Does anyone know if this could be a picture settings issue or calibration by the dealer? Or does it mean the panel is getting closer to its end? Thanks for all your help. Pictures will follow.
Dimitris-
DrDimitris
Greece
Posts 699
Dimitris-
DoubleU
Posts 562
DoubleU replied on Thu, Jun 21 2012 8:09 AM
It's dust between the diffusion layers inside your panel. It can be cleaned, but it's a lot of work!
DrDimitris
Greece
Posts 699
Dimitris-
DrDimitris
Greece
Posts 699
DoubleU:
Are you sure DoubleU? At least this is encouraging. When you say a lot of work, i think you refer to be brought to dealer service?
Dimitris-
DoubleU
Posts 562
DoubleU replied on Thu, Jun 21 2012 8:15 AM
Not sure though. If your lucky, it's only the glass-panel.
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Thu, Jun 21 2012 9:52 AM
What you have is a common fault on the Mk1 and early Mk2 screens.  When collecting we always go into the white test scale menu (on the service menu) to expose this issue.  If we see clouding, we don't buy - it's not worth it.
The 7-32 has flourescent backlighting and the light is dispersed by a diffuser which can discolour with heat, giving these cloudy sections where the light isn't being dispersed evenly - hence the dark patches.
Here's the issue...  The diffuser is an integral part of the LCD panel, so it's a panel replacement - even though the actual screen isn't faulty.  I was told by an engineer that for an extra £5-10 in production, the diffuser could have been made a separate part.. but that never happened.
DrDimitris - In fairness, I don't think it'll get much worse on your screen. That's as bad as they get on the whole - I've only seen a few worse than that.
Sorry for the bad news..  Erm..
Lee
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Thu, Jun 21 2012 1:34 PM
I once had a BV7-32 without HDMI lended by my dealer when my BV10 broke (see pic) and the middle of the screen had circular dark spots like on your Tv.
It happened only on bright pictures.
At the time, I thought I would have been furious if it was my Tv.
So I confirm the very bad news for your panel.
Gregory
DrDimitris
Greece
Posts 699
Thank you all for your assist. Yes. i had a verdict from my local B&O Service and they said it is the backlight of the panel that has the issue. The cost for replacing it will be 1200 euros including work, VAT and 1 year warranty. As i am not on the sweet spot of changing to a bigger panel right now, V1 would mess my Beolink around the house, i am thinking of going to change the panel.
What do you think of the price? Is it worth to get 3-5 more good years with my setup? And also is it possible to order a panel from higher MK's(e.g. MKIII, IV or even VI)??? (Service say no, we can only have a new MKII panel, same as the old one, but i trust you guys more) Smile
Dimitris-
jkhamler
Posts 286
jkhamler replied on Thu, Jun 21 2012 4:17 PM
Ouch - I certainly wouldn't spend €1,200 on a panel repair when there appear to be plenty of BV-7-32 panels floating about on eBay for much less than that (in the UK) anyway....
I would sell your current panel for 'spares/repairs' for a couple of hundred and then source a good used 7-32 panel to drop in.
But that's just my opinion!
DrDimitris
Greece
Posts 699
jkhamler:
Thanks for that jkhamler  Smile. But UK is easier on B&O stuff than Greece i am afraid. Ebay purchase with shipping to Greece is far more risky and costs enough to put you away. In local market is very rare to find. So i ended up on this option.
I just want to know from Lee or others who might know if i can only replace it with a MKII panel or i can go for a newer one that fits in the old chassis.
Dimitris-
Nick
Nottingham
Posts 785
Nick replied on Fri, Jun 22 2012 8:13 AM
I have had these on my set for a long while now, they haven't got any worse and I can live with it. I wear glasses and its almost like they need a wipe!!
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Fri, Jun 22 2012 10:02 AM
DrDimitris:
A common misconception is that the latest 7-32 panels are totally different.  Aside from the contrast ratio improving, they're all 720p - right up to the last one to leave Struer..
Lee
DrDimitris
Greece
Posts 699
DrDimitris replied on Fri, Jun 22 2012 10:16 AM
Thank you Lee. Dealer says that he email back Struer before they order on this. But he still did not know this. So thanks once again for your help. I always feel better relying on friends here, than service guys. Wink
@Nick : I was also reluctant Nick. .But slowly i feel it messes with my nerves...Big Smile
Dimitris-
Page 1 of 1 (14 items) | RSS
