Essence Remote Question
This post has 15 Replies | 1 Follower
Razlaw
Posts 4,345
Razlaw Posted: Mon, Sep 28 2015 8:50 PM
I see where the Essence remote can be configured for other uses. Looking at the chart it looks like one of the options is Beo 4 Radio command. Does that mean that there is no way to use an Essence remote to activate N. Music or N. Radio, or A. Aux?  Only Radio?
I would like to use to activate N. Radio on my Beosound 5, but as I also have a Beosound 3000 connected it looks to me like all I could do with the Essence remote is activate the radio in the 3000?
Raeuber
Germany
Posts 2,542
Raeuber replied on Mon, Sep 28 2015 10:27 PM
Hello Razlaw,
as far as I know you can also send the RADIO command if the Essence Remote is set to Beo4 mode.
BTW:
1. If set to Beo4 mode you can't remote the Essence with the remote. You have to use Beomusic app to start music from Essence.
2. If you connect the Essence to A.AUX of e.g. Beosound 3000 it is not possible to start music with one step: First activate A.AUX of BS 3000 and second press button of Essence Remote or use Beomusic app. Not a perfect solution in my opinion.
Regards
Räuber
Razlaw
Posts 4,345
Razlaw replied on Mon, Sep 28 2015 10:58 PM
Yes, I agree not a perfect solution. But for my purposes, most likely a satisfactory and cost effective solution. If I just want background music I will use N. Radio or N. Music from the Beosound 5 and thus still have one press access to music. If I want to choose specific music, that is when I will use the Essence. So I will press A. Aux on the Beo 4 and then use the app to select what I want to listen to.
I also have an unused Active Kit eye/receiver in the wall. I noticed Set Top Brackets has an adapter that allows the Essence Remote to be placed in the already present mounting. Looks beautiful. I would like to be able to put an Essence Remote in there and have access to music with just one touch of it. But it does not seem possible to have it activate N. Music or N. Radio.
I suppose I could remove the 3000 (and it's radio) from the system. Then connect the Essence to the Aux In on the Beosound 5. And assign Radio to N. Radio.
Then pressing Radio on the Beo 4, or pressing the Essence remote would start N. Radio which is my goal. I really don't need the 3000 connected to the system anymore. I just like the way it looks and occasionally seeing the glass doors open is part of the B and O magic.
Raeuber
Germany
Posts 2,542
Raeuber replied on Mon, Sep 28 2015 11:18 PM
I would keep BS 3000 as I would never sort out my BS 9000. Both are real design masterpieces. And to see rotating CD in these devices is still absolutely magic and will ever be.
The Essence is a streaming device for the new modern times. But you have to hide it because it's so ugly, no B&O feeling at all!
Yust my 2 cents.
Räuber
Barry Santini
New York
Posts 543
Raeuber:
This is how I work my essence, except that I've connected it to the aux in of my BS9000
B
Razlaw
Posts 4,345
Razlaw replied on Tue, Sep 29 2015 12:33 AM
Thank you very much for the comments and input.
leosgonewild
Helsinki, Finland
Posts 2,373
Having the remote in Beo4-mode and pressing the button (sending radio command) will start n.radio.
I had it set up with tune-in, and pressing the button made the last radio channel chosen to start playing.
Razlaw
Posts 4,345
Razlaw replied on Tue, Sep 29 2015 1:14 PM
So it will start N. Radio regardless of what the last source was? And start the last  N. Radio channel playing?
Razlaw
Posts 4,345
Razlaw replied on Mon, Oct 5 2015 10:01 PM
Another question about the Essence Remote.  Will it control the volume of whatever source is playing?  With the Beo 4 it does not matter what source is playing and what source is displayed on the Beo 4, it will still control volume. For instance, with the Beosound 5 playing, even if the last button pressed on the Beo 4 were DTV and DTV is displayed in the screen, it will still control the volume.  Thanks!
TWG
Posts 1,672
TWG replied on Tue, Oct 6 2015 10:21 AM
- Essence remote can control volume of audio or video sources. But you can't change the mode on the fly. You have to set it into Beo 4 audio or video mode and only video sources that listen to the Beoremote one. Here's the documentation from B&O: http://www.beointegration.com/uploaded/BeoSound_Essence_Remote_IR_modes.pdf
Short press in Beo 4 radio mode (Beosound): Radio
Long press: CD
So you could set the Beomaster 5 as an audiomaster and reassign the commands. Than the Beomaster 5 will start N.Radio with a short press on the Essence remote and N.Music if you press longer.
It should work this way. Can't test it at the moment as my Beosound 5 is currently not in my B&O setup.
Razlaw
Posts 4,345
Razlaw replied on Tue, Oct 6 2015 1:21 PM
Thanks! I had previously looked at the document you posted and I thought it would work, exactly as you described, however was not totally sure if I was reading it correctly. Thank you for confirming that my reading of the document was correct.  Very much appreciated!
AnalogPlanet
Vienna, Austria
Posts 678
And another question on Essence Remote: when it is sold as table remote version, I remember at introduction there were different metal plate colors shown... ...now it seems only gray is available?
Anyone perhaps has a "demo" or "test production" metal slate in a different color or could that be ordered from a reseller?
BeoBoy68
Alsace 🇨🇵
Posts 1,247
BeoBoy68 replied on Tue, Oct 13 2015 11:18 AM
AnalogPlanet:
Shame that another Colors are not available. Embarrassed
I like the light blue Big Smile
AnalogPlanet
Vienna, Austria
Posts 678
Well I'd take any just to easily differentiate one remote from another. Big Smile
And I agree light blue is nice.
elephant
AU
Posts 8,219
elephant replied on Wed, Oct 14 2015 10:57 AM
BeoBoy68:
I agree
I was surprised when ordering mine that the option had disappeared
BeoNut since '75
Sal
California, USA
Posts 1,197
Sal replied on Thu, Oct 15 2015 3:30 AM
elephant:
Does this mean that at one point, different colored bases were available to the general public?
Page 1 of 1 (16 items) | RSS
