Beocord 5000 tape not loading
This post has 12 Replies | 0 Followers
yiancar
Posts 18
yiancar Posted: Mon, Sep 28 2015 9:01 PM
Can someone measure the ac voltages of the main transformer unconnected from the power supply? the 0.15ohm resistor right after the transformer was blown so I want to check that the transformer is intact.
Yiangos
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Tue, Sep 29 2015 4:41 PM
I would measure if there isn't a shortcircuit behind the resistor (I think there is not, or a possible capacitor is shortning the circuit). Just replace the resisitor. If there would be a problem in the transformer, then a) the resistor wouldn't have blown and b) will not produce a higher voltage then expected (if for instance several windings are melted).
You could use a variac to turn up the AC voltage slowly, or use a lightbulb in series with the BC5000.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Sep 29 2015 11:07 PM
If I remember correctly, this resistor is a flame-proof type.
Don't fit anything else.
yiancar
Posts 18
yiancar replied on Wed, Sep 30 2015 10:24 PM
Done that, 5 volt rail is back alive :) Thank you guys
drawer opens but the tape mechanism seems wrong, i put a tape but it does not turn a small silver pin is turning tho continuously.
any ideas?
yiancar
Posts 18
yiancar replied on Sun, Oct 4 2015 10:05 PM
Ok so the problem seems to be that the heads do not move forward to lock on the tape. The tape is detected, as when i put it in the motor starts spinning but thats about it. any idea what else can i check?
Dillen
Posts 13,191
Dillen replied on Sun, Oct 4 2015 10:42 PM
Have you checked the belts ?
Can you tell if the capstan is rotating ?
Will it wind and rewind ?
yiancar
Posts 18
yiancar replied on Sun, Oct 4 2015 10:46 PM
belts are ok, capstan is turning but no wind or rewind
The tape is not "loading", the heads do not move into place
Dillen
Posts 13,191
Dillen replied on Mon, Oct 5 2015 1:03 PM
Sounds as if the belts are not on correctly.
Check the path of the square belt below decks.
It should be driven by the motor pulley (- not just pass it on both sides).
yiancar
Posts 18
yiancar replied on Mon, Oct 5 2015 5:09 PM
belt path seems correct, the solenoids are not engaging i think, when i press play i get for 1 second 7v across the play relay but i dont hear or see it move. I will try to manually apply a voltage and see if it moves. btw i get 170ohms resistance on it
yiancar
Posts 18
yiancar replied on Mon, Oct 5 2015 8:46 PM
Update: I have Dissasemble the tape mechanism and relubricated everything ( i suspected that it might be too much friction). Saddly it has no worked
Can anyone measure the require voltage for the solenoids to work, I think thats the problem.
Dillen
Posts 13,191
Dillen replied on Tue, Oct 6 2015 7:23 AM
Can you provide a photo of the underside of the drive?
yiancar
Posts 18
I have attached a picture. If the belts are correct I have found the problem. TR13(bd136) its base - emitter does not conduct resulting in only 7 volts for the relay instead of 16 (24v reference). I will order some and give it a try
yiancar
Posts 18
yiancar replied on Fri, Oct 9 2015 7:21 PM
And the tapes load perfectly now:)
Onto the next issue, PPM. Should it light up during playback? or it only happens during recording?
If it should during playback, mine is dead. Any common parts to check?
Update: She is all fixed up now, it was a dead 4011 chip:)
Page 1 of 1 (13 items) | RSS
