RX2 suspension problem
This post has 7 Replies | 0 Followers
Wyzard
Posts 6
When I put a record on the platter some of the records scrape the record player because I think the platter is a little low. Is there a way to readjust this so the platter is above the edge of the player? I noticed that the  Suspension is very sensitive. I believe that if adjusted only a 1/6th of an inch up would do it.
If you look at the picture I provided you will see the platter is almost flush with the turntable making some records scrape the turntable. I believe there is a way to adjust this so it is raised just a hair.
Søren Mexico
Mexico City
Posts 6,411
There is a Repair manual on site for silver and gold members, it includes a description of the procedure.
Wyzard
Posts 6
Wyzard replied on Tue, Sep 29 2015 2:06 PM
I'm not a silver or gold member so that does not help at all. Any one else have a fix for this?
Søren Mexico
Mexico City
Posts 6,411
Here you go
Rich
Orlando, Florida, USA
Posts 2,598
Rich replied on Tue, Sep 29 2015 6:11 PM
Wyzard:
Yeah, I think Soren was subtly suggesting you upgrade your membership.  Lift the platter off, find the 3 leaf springs, and bend them.  The procedure is as crude in execution as it sounds.  Trial and error.  Lots of trial and error.
Wyzard
Posts 6
Wyzard replied on Tue, Sep 29 2015 8:45 PM
Thank you guys very much. I fixed it!
Rich
Posts 2,598
Rich replied on Fri, Oct 2 2015 6:20 PM
Congratulations, and thanks for taking the time to report back your success.
Søren Mexico
Mexico City
Posts 6,411
Good work, dont be a stranger now.
Page 1 of 1 (8 items) | RSS
