Beocenter 8500 in Multiroom
AnalogPlanet
Vienna, Austria
Posts 678
AnalogPlanet Posted: Tue, Sep 29 2015 5:11 PM
Yes, I know it could be impossible or too much hassle. Big Smile But my Beocenter 8500 is like a beautiful object d'art and I really want to try adding it somehow to Multiroom. After a lot of research, I am still puzlled as I never understood ML and MCL properly (I am fresh to B&O).
Few comments:
1.) I just need to be able to "add" BC8500 with attached speakers to multiroom, not use it as a source
2.) I have Apple Airport Express today connected to it and I stream via AirPlay
3.) Apart from Beolink Converter NL/ML I don't mind buying an optional IR Receiver for simple operation
What I don't understand yet:
Could it be I only miss ML-->MCL cable adapter if such thing exists?
Since I stream everything wirelessly around the house, how the Beolink Converter joins BC8500? Does it have WiFi built in?
Confused
AnalogPlanet
Vienna, Austria
Posts 678
So, two years later I still haven't decided which path to take? :)
One option that looks elegant is buying a BS Core and connect BC8500 to its line in input. With that, I have no control whatsoever on CD play/stop/next/previous from the B&O app naturally. But I can share CD sound from BC8500 across multiroom which is what I ultimately want to achieve.
The alternative, if I get it correctly, is first a MCL/ML converter followed by a Beolink Converter 1790. If set up properly this should allow I believe basic controls of CD playback? Just to reconfirm and evaluate how much it makes sense to go this route...
TWG
Posts 1,672
TWG replied on Tue, Jan 2 2018 10:25 AM
Someone here in the forum posted that he was able to control an old Beogram through the Beolink Converter 1790, so I guess that's the better way to go.
But I'm just guessing as I currently have no 1790. Other forum members can explain the 1790 functionality better.
Page 1 of 1 (3 items) | RSS
