Some New Features for Philips Hue and MLGW
beojeff
USA
Posts 2,012
beojeff Posted: Wed, Sep 30 2015 11:15 PM
I've written some new custom strings for controlling the Philips Hue with the MLGW. I've written a command to gradually turn off the lights over five minutes and another one to gradually turn on the lights over 5 minutes. This could be a nice way of gently lowering the lights for sleep and to gentle turn on the lights for waking up. A transition time value of 3000 is for 5 minutes. 6000 is for 10 minutes. 9000 is for 15 minutes. Often, computer code inserted into posts on this forum posts incorrectly. I'll try anyway. If it doesn't post correctly and anyone wants me to email them the strings, just PM me.
To gradually turn off the lights:
PUT /api/<username>/groups/0/action HTTP/1.1\0D\0AContent-Length: 39\0D\0AContent-Type: application/x-www-form-urlencoded\0D\0A\0D\0A{\"on\": false, \"transitiontime\": 3000}
To gradually turn on the lights:
PUT /api/<username>/groups/0/action HTTP/1.1\0D\0AContent-Length: 38\0D\0AContent-Type: application/x-www-form-urlencoded\0D\0A\0D\0A{\"on\": true, \"transitiontime\": 3000}
beojeff
USA
Posts 2,012
beojeff replied on Wed, Sep 30 2015 11:16 PM
It seems that the command lines posted correctly.
beojeff
USA
Posts 2,012
beojeff replied on Wed, Sep 30 2015 11:19 PM
You can also transition to a specific hue, brightness, and saturation. Here is a command that will gradually turn all lights to grey:
Normal 0 false false false EN-US JA X-NONE PUT /api/<username>/groups/0/action HTTP/1.1\0D\0AContent-Length: 55\0D\0AContent-Type: application/x-www-form-urlencoded\0D\0A\0D\0A{\"on\": true, \"bri\": 46, \"hue\": 39816, \"sat\": 253}
beojeff
USA
Posts 2,012
beojeff replied on Wed, Sep 30 2015 11:23 PM
You can also gradually transition to a specific Scene. Here is an example of a command that would transition all lights to the "Relax" Scene:
Normal 0 false false false EN-US JA X-NONE PUT /api/<username>/groups/0/action HTTP/1.1\0D\0AContent-Length: 55\0D\0AContent-Type: application/x-www-form-urlencoded\0D\0A\0D\0A{\"scene\": \"1dd4b4869-on-0\", \"transitiontime\": 3000}
beojeff
USA
Posts 2,012
beojeff replied on Wed, Sep 30 2015 11:25 PM
As I feared, the last 2 posts added language in front of the command lines. The command lines should all begin with "PUT."
beojeff
USA
Posts 2,012
beojeff replied on Wed, Sep 30 2015 11:28 PM
beojeff:
Correction: This is the correct command to transition all lights to grey:
PUT /api/<username>/groups/0/action HTTP/1.1\0D\0AContent-Length: 81\0D\0AContent-Type: application/x-www-form-urlencoded\0D\0A\0D\0A{\"on\": true, \"bri\": 46, \"hue\": 39816, \"sat\": 253, \"transitiontime\": 3000}
Page 1 of 1 (6 items) | RSS
