HI
I bought my Penta 2 speakers few months ago from ebay , and both works perfectly but one of the display doesn't show anything i checked all conection and every thing else which i thought might be the reason but no luck . Is there anyone who can help me regarding to this matter , or any tips ? thanks
I've had these displays (mk2) several times for repair.
The inner electronics becomes unreliable due to bad solder joints. But check the switch first. Another cause could be a powerfaillure in the amplifier at the bottom of the penta. If you swap the displays, then you can eliminate.
Hi
thanks for your tips , as you mention i moved the switch underneath from video to audio and display came to life .
best regards
shahram
Just to let you know as you said i checked the switch underneath and moved it from video to audio and display start working . Thank you for your help and tips .
Best regards
