I will shortly be moving house, and reconfiguring my hifi system. I currently use a BeoSound 9000 as my CD player, with a direct digital feed into my BeoLab 5s. However, years ago I had a BeoGram CD 5500 (which, if I'm correct, is the only other B&O CD player with a digital output) and recall it being an outstanding machine. Has anybody compared these two models for sound quality? Would I do better to acquire a BeoGram CD 5500 and use it as my CD player instead?
The CD5500 is a great sounding player in analogue mode, but I doubt you'd hear any real difference if you use the digital outputs. You would also lose remote control: with a standalone CD5500, all you can do is step the track forward from the front panel.
--mika
My CD4500 has a dig-out too...
....and you can control it from the front panel ;-)
Interesting! So there are four models to choose from. Which would sound the best using the digital output or would there be little or no difference? Alternatively, would I get better sound using the analogue output from one of them?
politician:I will shortly be moving house, and reconfiguring my hifi system. I currently use a BeoSound 9000 as my CD player, with a direct digital feed into my BeoLab 5s.
If your 9000 works why not keep it ?
Yes, it works perfectly and looks stunning — so I'll almost certainly do as you suggest. I was just checking whether I could get better sound with a different player.
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
My Beogram cd 6500 has a digital coax output as well, so looks like there might be quite a few B&O models with this facility. As others have said unlikely you'd hear any difference with digital outputs, but the beosound 9000 is beautiful - I've always fancied one!
If you actually use a CD player, then the BS9000 is unbeatable IMHO. I sold mine, but only because I never used it.
Too long to list....
politician:I will shortly be moving house, and reconfiguring my hifi system. I currently use a BeoSound 9000 as my CD player, with a direct digital feed into my BeoLab 5s. However, years ago I had a BeoGram CD 5500 (which, if I'm correct, is the only other B&O CD player with a digital output) and recall it being an outstanding machine. Has anybody compared these two models for sound quality? Would I do better to acquire a BeoGram CD 5500 and use it as my CD player instead?
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
