PUC code NVIDIA SHIELD ANDROID TV 4K
This post has 15 Replies | 3 Followers
FRDRCJRDN
LYON, FRANCE
Posts 17
Silver Member
FRDRCJRDN Posted: Fri, Oct 9 2015 9:57 AM
Hi everyone,
Do you know where I can dowload the PUC code for the NVIDIA SHIELD ANDROID TV ?
I connected it to the HDMI 1 of my BEOVISION AVANT 55 and I have great 4K videos ! But I would like to use the BEOREMOTE ONE instead of the NVIDIA SHIELD REMOTE...
The NVIDIA SHIELD ANDROID TV is HDMI 2.0 and HDCP 2.2 compatible and you can read HEVC 4K files without problem !
Michael
Sweden
Posts 2,578
Michael replied on Fri, Oct 9 2015 10:31 AM
There probably isnt any PUC for it yet but ask B&O customer support for it! This box seems perfect for HEVC-files and 4K file streaming (if it can access it locally as well).
It also has Netflix UHD (4K) so that is just perfect! I think I want to order the same box also. It also has IR receiver (just for Logitech harmony) so it WILL work with B&O also.
Very very interesting box.
Gigabit ethernet as well.
Michael
Sweden
Posts 2,578
Michael replied on Fri, Oct 9 2015 10:33 AM
Oh, and a fan. Fail.
Michael
Sweden
Posts 2,578
Michael replied on Fri, Oct 9 2015 10:57 AM
And one thing to be extra cautious about is that BeoVision avant has only ONE HDCP 2.2 port. The other ones are just HDCP1.4 (which is quite weird actually).
FRDRCJRDN
LYON, FRANCE
Posts 17
Silver Member
FRDRCJRDN replied on Sun, Oct 11 2015 9:45 AM
Hi Michael,
Thanks for your reply.
I've just asked to the B&O support.
Netflix's TV Shows in 4K on the Beovision Avant are fabulous !
Michael
Sweden
Posts 2,578
Michael replied on Sun, Oct 11 2015 1:16 PM
FRDRCJRDN:
Hi Michael,
Awesome! I am curious about box but it's a tad expensive and it's an android box. I'm a mac geek but I don't mind trying an android box. I'll consider it Smile.
How have you placed yours?
I think they sell it in a very strange way, without stand and remote. Odd.
Michael
Sweden
Posts 2,578
Michael replied on Thu, Nov 5 2015 12:24 AM
There is a PUC for nvidia shield now!
quader
Posts 109
quader replied on Sat, Nov 7 2015 12:00 PM
Hello
what made you choose this box
why not PS3/4
i am interested to watch 4k content particularly 4k films
can you you not stream through webmedia ?
Michael
Sweden
Posts 2,578
Michael replied on Sat, Nov 7 2015 3:12 PM
quader:
Hello
why not PS3/4
Not 4K.
FRDRCJRDN
LYON, FRANCE
Posts 17
Silver Member
Thanks for the info !
I contacted the B&O support who told me that I have to pay for the development of the PUC code... It seems that they changed their mind...
But it didn't work for me.
Anyone tried ?
w5bno123
London
Posts 578
w5bno123 replied on Mon, Nov 9 2015 10:49 AM
Hi
The PUC code is readily available to download from the TV itself.
Michael
Sweden
Posts 2,578
Michael replied on Mon, Nov 9 2015 11:14 AM
FRDRCJRDN:
Anyone tried ?
They told me the same. Which I found quite bad from a customer standpoint. Then what's the reason for an online PUC library. But yes, then I found it online in their catalog anyway.
It seems their customer support isn't really well connected with the software developers.
steve1977
Posts 911
steve1977 replied on Sat, Dec 3 2016 11:16 AM
Was also looking to buy a Shield to connect with my BV7. Assume I am out of luck with a PUC?
riverstyx
SouthWest UK
Posts 938
steve1977:
The new .decx (v3.x) PUCs used by the current generation of beovisions can be converted to the older .dec (v2.x) format used by the ML generation beovisions using a software tool available to dealers and service engineers - the converted PUC can then be installed on the BV7.
This will obviously require a service visit as is the case with any PUC table update on the older beovisions but it is certainly possible.
Martin.
steve1977
Posts 911
steve1977 replied on Wed, Jan 30 2019 6:47 AM
riverstyx:
steve1977:
Martin.
Thanks a lot. I only now realized you had replied.
Besides Nvidia Shield TV, is there also a PUC for the Mi Box (or is it even the same PUC)?
Also, any idea whether this is feasible without a service engineer?
TWG
Posts 1,672
TWG replied on Wed, Jan 30 2019 8:50 AM
You don't need the right PUC, there are other solutions like the IR-USB-Receiver FLIRC that you can use with Nvidia Shield or every other components that can handle USB-Keyboard-Inputs etc.
Maybe this thread helps:
https://archivedforum2.beoworld.org/forums/p/35059/259882.aspx#259882
Page 1 of 1 (16 items) | RSS
