Beovox/Lab 3000/4500/5000 wall bracket - SOLVED
This post has 4 Replies | 0 Followers
js
Posts 382
js Posted: Fri, Oct 16 2015 10:53 AM
I need only one single bracket (but I am happy to buy a pair as the chance of finding just one may be small).
I am looking for a reasonably priced offer (alternative is STB at £60).
I am based in Belgium.
Many thanks Smile
Dave Farr
France
Posts 2,283
Dave Farr replied on Sat, Oct 17 2015 4:32 PM
If you already have one, can you not find a metal workshop to just replicate it?  It's a really simple bracket.  Probably a lot cheaper than anything else. Otherwise, the £60 from STB is probably what you could pay for an original pair on eBay.
You could also buy a piece of steel plate at your local DIY shop and make one it's so simple in design.
Dave.
js
Posts 382
js replied on Fri, Oct 23 2015 1:39 PM
Thanks Dave, good advice, much appreciated.
js Smile
Dave Farr
France
Posts 2,283
Dave Farr replied on Fri, Oct 23 2015 2:21 PM
Which option did you take then?
js
Posts 382
js replied on Mon, Oct 26 2015 5:56 PM
Simply DIY. Good result Smile
Page 1 of 1 (5 items) | RSS
