Can the 7/1 speaker fitted to the 7-32 TV be fitted to the 7-40 TV and vice-versa?
Faily urgent please
Many thanks
Brian
Thanks, Kallasr. The problem is, the 7-40 being delivered won't fit into the space allotted for it with the 7/2 speaker, but it will if changed over with my 7-32 with the 7/1. I think the performance should be much the same as they both seem to be of similar power output. I don't want the installer to tell me it can't be done!
Thanks again.
